11-07-2010, 08:57 PM | #51 |
Tot Roddin'
Re: kyb shocks/ part numbers
Give Stan/Mark a call at ECE.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
11-08-2010, 09:20 AM | #52 |
ECE uses their own part number, but when I called I was told they use the same shocks for 2/4 all the way to 4/6 drops. I did alot of research and I ordered my KYB shocks from Summitt as they had the best price. I went with 344055 for the rear ($27.31 each) and 344068 on the front ($23.06 each). I am very happy. I cut 1 front coil and used Jeep TJ springs in the rear. I also relocated my rear shocks. Rides 10x better. Summitt will tell you the 344055 is for the rear of a Nissian Quest van but it is KYB part number that ECE sells with their own part number. I hope this helps.
73 C-10 Cheyenne Super 454 60 Impala LS powered 16 Camaro 2SS 6speed 12 Ultra Classic 71 Vega Wagon V8 4 speed |
11-13-2010, 10:31 AM | #53 |
If I am only doing lowered spindles for the front, do I need the lowered shocks? 3" drop spindles. I read somewhere on here the lowered shocks are only factored based on springs.
11-13-2010, 11:06 AM | #54 |
No, you wont need to unless your dropping with springs on front and rear with springs. The drop spindles use the same shock as stock, since the drop spindle doesnt change the height of the shock mounts.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-22-2010, 12:21 PM | #55 |
Not real clear on the GR-2 front and rear part numbers. This will be for a bagged 70 C-10 with porterbuilt front control arms.
03-17-2011, 08:37 PM | #56 |
born to lose
awsome thread it saved my ass today!
_____________________ '67 Chevy Belair Wagon 283 Powerglide '68 Chevy II Nova 2 door 350 TH400 Sold!! '71 Chevy C20 350 TH350 '71 Chevy C10 Burb 350 TH350 stolen totalled gone.... Burb Build http://67-72chevytrucks.com/vboard/s...d.php?t=475155 Nova Build http://67-72chevytrucks.com/vboard/s...d.php?t=498979 Wagon Build http://67-72chevytrucks.com/vboard/s...d.php?t=543052 Not giving a truck. |
03-18-2011, 10:43 AM | #57 |
I know this is about KYB shocks but thought I would mention this for those of you that dont know. If you buy summit brand drop shocks they are actually Doetsch Tech shocks. I ran them on my bagged s10 a few yrs ago.
04-13-2011, 07:26 PM | #58 |
Do the kyb pt#S 344055 and 344068 also work for bagged vehicles (72 blazer)? (Rear notch and bags, front bagged with 3" drop spindle). Any part number on the summit brand shocks?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
04-14-2011, 11:25 AM | #59 |
I purchased the 344068 kyb's and have a 2/4 drop. The shock was way too close to bottoming out, something like 1.5" of travel before hitting bottom. Double check your measurements. Im keeping the shocks but going to install a front shock relocator kit to gain a couple inches of travel back
06-14-2011, 10:30 PM | #60 |
06-14-2011, 10:33 PM | #61 |
D
Posted via Mobile Device |
06-14-2011, 10:36 PM | #62 |
Is the ride good
08-02-2011, 01:58 AM | #63 | |
'69 Chevy SWB
I was researching shock info and I thought I'd bump this back up. I see a few people asking about it still and there is a lot of good info here.
Matt '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
08-19-2011, 08:33 PM | #64 |
What info did you need to give them in order to match them up? I'm going with a 2/4 coil drop on my '67 and was wondering what info I needed to have handy when I called.
Thanks. |
09-07-2011, 12:11 PM | #65 |
i'm looking for shock numbers for a 72 leaf spring truck lowered 4 to 5 inchs... any help..
72 swb pickup http://i124.photobucket.com/albums/p...k/100_0958.jpg 1967 chevelle ss 1966 mustang getting a l33 ls motor 1969 chevy dump truck 1989 mustang 6.0 ls best time of 1.29 at 5.91 https://www.youtube.com/watch?v=JtbooZoGZmQ |
09-07-2011, 01:36 PM | #66 |
http://www.kyb.com/technical/documen...onsSecured.pdf
Look here. Gives all spec on kyb's Mounts lengths Part # then punch it in summit or jegs or google Posted via Mobile Device |
09-07-2011, 04:45 PM | #67 |
well it looks like the 344068 is going to work with leaf springs with a 4 to 5 inch drop...
hey thanks for posting that....
11-05-2011, 05:31 AM | #68 | |
VA72C10
Great info!
Looking for a 67-72 swb or blazer project in or around VA. |
11-20-2011, 10:56 PM | #69 |
Just a heads up, but the hardware that comes with the 344068 (front shock) is actually supposed to be used for the rear shocks (344055)..at least that's the way my boxes were packaged straight from kyb..took me a while to figure that out..duh
05-25-2012, 03:28 PM | #70 |
VA72C10
Bringing this great thread up with a question...
the 344068 shows it is the STOCK shock for a 67-72 truck...with NO drop... How is that correct for someone running a 2 or 3" drop spring? Sure seems it reduces the travel... and the 344055 isn't listed for the truck at all which might make sense because it would have shorter travel for the rear dropped???...stock shows 344085 for the rear...but that's for coil springs only...has no comparable spring listed for the rear with coils...maybe the 344055 is it then???
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 05-25-2012 at 03:40 PM. |
05-25-2012, 03:38 PM | #71 |
VA72C10
Also to add, if you search these part numbers on ebay you can get all four shipped to your door for $112...
05-29-2012, 10:49 PM | #72 | |
'69 Chevy SWB
I just ordered mine on Amazon, just under $250 shipped for four shocks and two Magnaflow mufflers.
05-29-2012, 10:55 PM | #73 |
VA72C10
cool! I love saving $$$
10-12-2012, 02:21 AM | #74 |
I see this post is dated....but any pictures of your shocks relocated, and the brackets you used or made? thank you!
02-19-2014, 11:06 PM | #75 |
Will the KYB 344055 and 344068 shocks work with a bagged 64 with 2.5" drop spindles and a bolt in notch in the back? Thanks
