Old 11-08-2010, 06:08 PM   #1
Rodk65
Rodk65's Avatar
C/20 Leaf Spring Questions.
I am finding so much conflicting information I am not sure what is correct. I have a 71 C/20 leaf spring suspension. ECE has a 4” drop leaf spring for a C/10 half ton truck. ECE lowering leaf springs are 2¼ inches wide with a half ton rating. I measured my C/20 springs to verify and my springs are also 2¼ wide. Is there any reason why I couldn’t swap my springs for a set of ECE drop leaf springs? I understand that it will lower my towing capacity but not so much that I wouldn’t be able to tow our boat and ATV's around. I would like to lower the stance and hopefully make it ride a little better. Any information is appreciated.
ROD
1969 K10 4x4 Short Fleet. Tuned Port Injection 350/700R4, Cruise, tilt and factory A/C.
1971 C20 Camper Special. 350/350. SOLD
2002 Chevy Tahoe LT
Rodk65 is offline   Reply With Quote
Old 11-08-2010, 08:58 PM   #2
swamp rat
swamp rat's Avatar
Re: C/20 Leaf Spring Questions.
My guess, and i say it from not having to do it or having any experiance with it would be that aside from the towing rating you would want to check the eye to eye length, and also the bolt and bushing diameters.
You didn't mention if this is a 2wd but i'm assuming so, did you also find something for the front? something to think about.
Also possibly the driveshaft may be too long if ya drop it that far??
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-08-2010, 09:18 PM   #3
sjarrett71
sjarrett71's Avatar
I found a lot of good info on this website: www.generalspringkc.com
They have measurements so you can compare. Their prices seem a little cheaper too. I don't know if they have lowering springs though but I'm sure you could contact them and ask.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 11-09-2010, 12:39 AM   #4
Rodk65
Rodk65's Avatar
The general spring web site is actually the site that got me thinking about this. My next question was to Stan at ECE. At first I was told that they wouldn't work but then I was told that if I had 2 1/4 wide springs then there leaf springs would work in my truck. I was wondering if anyone else had used ECE 1/2 ton leaf springs on a 3/4 ton.
ROD
2002 Chevy Tahoe LT
Old 11-09-2010, 01:22 AM   #5
1stimer
According to this thread, there were two different lengths for leaf springs for 73-87 trucks. Not sure if this is the same for the previous generation or not.
http://67-72chevytrucks.com/vboard/s...d.php?t=359363
1stimer is offline   Reply With Quote
Old 11-09-2010, 04:39 PM   #6
Rodk65
Rodk65's Avatar
I don't believe that in 71 there were different lengths but I can not say for sure. I am only going off of what I have read from some of the aftermarket spring shops.
ROD
2002 Chevy Tahoe LT
Old 11-09-2010, 05:03 PM   #7
cdowns
cdowns's Avatar
i'd check with a local spring shop for availability and suggestions for alternitves
Old 11-09-2010, 05:38 PM   #8
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
If you are going to lose capacity anyway, you might think about pulling some of your stock leaves out for a drop. I pulled 4 leaves out and it got me 4" lower. Here are some links to other threads on pulling leaves:
My writeup on pulling leaves
another similar thread
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 11-09-2010, 09:24 PM   #9
Mike C
Mike C's Avatar
I used the ECE lowering shackles on my 3/4 ton. The 2x4 had 2 1/4" wide springs, but the 4x4's and the 2x4 Longhorns had 2 1/2" wide springs. My thought is an inquiry to ECE is the place to start.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-16-2010, 01:01 AM   #10
playstock
use 1973 and newer lowering shackles. they are the same width as the longhorn leaf springs. I got them at ECE.
playstock is offline   Reply With Quote
