Old 11-09-2010, 02:09 AM   #1
mikie 1954
Question Carpet install
I 'am getting ready to put carpet in my truck& a friend asked me if it needed to be glud down or something else. I had not thought about it and don't know, can someone please answer this for me .THANKS MIKE
mikie 1954 is offline   Reply With Quote
Old 11-09-2010, 09:36 AM   #2
geezer#99
geezer#99's Avatar
Re: Carpet install
The carpet doesn't get glued down. However the jute backing or sound deadener does.
Then you put the carpet over it. Are you using a carpet that's moulded to fit?
geezer#99 is online now   Reply With Quote
Old 11-09-2010, 10:37 AM   #3
bobcostas
bobcostas's Avatar
Re: Carpet install
I got the carpet kit from Jim Carter in January. Its nice, but it's going to be larger than your cab. so, have a good box cutter on hand and a few replacement blades. I put down sound deadener as well. It makes a world of difference if you want a quieter ride. I didnt glue the carpet down because you might have to get into the trans tunnel for something. It would be a shame to ruin good carpet for something like that.
i got "fat mat" deadener. its cheaper than the name-brand stuff. a lot cheaper.
'64 Corvair Ragtop
'66 C10 Stepside
"The oxen may be slow, but the Earth is patient"
bobcostas is offline   Reply With Quote
Old 11-09-2010, 11:46 AM   #4
mikie 1954
Re: Carpet install
THANKS,This is what I thougt but didn't know for shure.I got carpet from STOCK INTERIORS, it's fitted and I see what your saying about the box knives.I've already put down sound deadner, now for the carprt. AGAIN THANKS MIKE
Old 11-09-2010, 03:05 PM   #5
Indian113
Indian113's Avatar
Re: Carpet install
How far under your seat does the carpet go?
Indian113 is offline   Reply With Quote
Old 11-11-2010, 02:46 PM   #6
mikie 1954
Re: Carpet install
The carpet goes back to the gas tank,would go to back of cab if you pulled the tank.
Old 11-11-2010, 04:47 PM   #7
Indian113
Indian113's Avatar
Re: Carpet install
Thanks mikie
Old 11-11-2010, 05:37 PM   #8
irish1966
irish1966's Avatar
Re: Carpet install
may I recommend doing the peel and seal before you do it. I did it and it makes a big difference. I have that, then the underlay stuff and then the carpet.
Cheers
David
66 LWB Fleet (on hold)
64 LWB Fleet (daily driver)
65 SWB Fleet (almost finished as a driver)
64 SWB Fleet (just started - "Tommys Hot Rods" tribute truck)
Nothing worth doing, is easy.
irish1966 is offline   Reply With Quote
Old 11-11-2010, 09:29 PM   #9
austex66
austex66's Avatar
Re: Carpet install
3M makes a spray adhesive that works great for that. I didn't glue mine down quite yet, but I will after paint...
66' Chevy SWB:350ci-th350,frt. disc brakes, pwr steering, 5-lug
waltshow.com/Chevy
austex66 is offline   Reply With Quote
Old 11-12-2010, 12:53 AM   #10
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Re: Carpet install
^^^I've always had great results using this method. I think the "Fat Mat" is a "peel and seal" type insulator as well.
fryer1979 is offline   Reply With Quote
Old 11-12-2010, 01:19 AM   #11
mikie 1954
Re: Carpet install
I got the peel & seel from ebay about $75 to do my truck with alot left. Works better when it's warm out, doesn't stick good if it's cold but not to hard to do.
Old 11-12-2010, 10:19 PM   #12
bama63
bama63's Avatar
Re: Carpet install
i have used auto custom carpets for many years http://www.accmats.com/ and they also offer kick panels,door panels as well as rear cab wall carpets and sound deadening mats custom molded to fit our trucks and even bed carpet for you stepside guys
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 09-23-2012, 10:18 AM   #13
Hx16457
Hx16457's Avatar
Re: Carpet install
Looking for help, I am installing gas pedal "with carpet". She is a 1965 c10. My question is how to cut the carpet; is it "cut just around the pedal studs", or is it "cut a slit between the studs", then slip th lower flat portion of the pedal under the carpet through that slit?
Hx16457 is offline   Reply With Quote
Old 09-23-2012, 01:04 PM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Carpet install
I didn't keep the stock gas pedal since my truck is DBW, but when I put carpet in...the pedal stud could unscrew from the floor. I'm not sure if thats normal, but if so I'd think it would be easiest to just use a ice pic to find the hole, then cut a small X with a knife and see if you can fit the stud in there.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-23-2012, 01:30 PM   #15
Hx16457
Hx16457's Avatar
Re: Carpet install
Thanks for the reply, I had not thought of screwing the studs back down onto the carpet! Great idea, might put some washers under them to help hold the carpet down better too, I'll give it a try, and let you know
Old 09-24-2012, 06:03 AM   #16
Hx16457
Hx16457's Avatar
Re: Carpet install
I ended up just removing a bit of the jute padding on the carpets backside at the pedals location. I have sound-deadening material down, so it was too thick at the pedal site. Problem solved!
Old 03-20-2013, 06:21 PM   #17
Tom66C10
Re: Carpet install
How far to the firewall does the carpet go? Does it go over, or under the rubber/jute firewall pad?
Thank you.
Tom
Tom66C10 is offline   Reply With Quote
Old 03-20-2013, 08:25 PM   #18
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Carpet install
Only goes about half way up the fire wall, where the floor stops angling into the firewall. Mine overlaps the jute.
Old 03-21-2013, 08:49 AM   #19
1963c-10
1963c-10's Avatar
Re: Carpet install
Any pics?
1964 Short bed trailer
