Old 11-14-2010, 09:13 AM   #1
Born Lucky
Driving at 55 MPH
I do not mind driving my truck at 55 MPH but the noise is driving me crazy!
I satarted the Dynomat thing and it has gotton a little better. I seem to be getting most of the noise from the engine. I have a 292, 4 speed trans with a Eaton HO52 rear end.
The noise is especially bad when I close the windows. I am considering installing a hood insulation to tame the beast. Will this provide releive?
Born Lucky is offline   Reply With Quote
Old 11-14-2010, 09:28 AM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Driving at 55 MPH
Is the exhaust hanger connected to the cab? Do you have a tailpipe or a turn down behind the cab? Sounds like somethings touching or attached. All the holes in the floor are blocked?
Old 11-14-2010, 09:52 AM   #3
Born Lucky
No, it is none of those things.
All new exhaust, clamps etc...
It seems to be a insulation problem.After installing the dynomat things got better. The truck is all metal in the interior so sound control is a problem.
I am thinking of installing this http://shop3.mailordercentral.com/su...ts.asp?dept=17
Old 11-14-2010, 10:06 AM   #4
aerotruk63
aerotruk63's Avatar
I helped install Dynomat and the foam in a 31 Chev 5 window coupe, It wasn't till we installed Dynomat inside of the doors that the sound in the car became reasonable. Seems if you want it quiet inside you have to put the stuff everywhere.
Old 11-14-2010, 10:39 AM   #5
'63GENIII
'63GENIII's Avatar
I agree about having to put that stuff eveywhere. My firewall is next. What is the foam that you mention Aerotruck? I'm always up for noise reduction!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 11-14-2010, 10:43 AM   #6
jocko
jocko's Avatar
I've been seeing more use of "lizard skin" spray in sound/heat deadening. Not sure how well it works - but I'd be sure I want it for life before I spray it. But the same could be sead of dynamat also... Just another option. Probably messier than stick-on matting though.
Old 11-14-2010, 11:01 AM   #7
aerotruk63
aerotruk63's Avatar
I believe that the foam was from Dynomat as well, but not sure. It was similar to the product in the link in Born Lucky's post above. Installs easier with two people. Trick is to refrigerate the sheets before installing, cause if their warm and touch anything, it's stuck! The 31, left the foam as an interior finish in the trunk. He put a carpet over the trunk floor pan foam though. Don't wear latex gloves when installing, he found out the hard way! Dynomat foil to start with then the foam on top. Adds weight though!
Old 11-14-2010, 11:33 AM   #8
'63GENIII
'63GENIII's Avatar
Oh I think I get it. I thought the foam was a product that was sprayed up into the pillars of the cab.
Chris
'63 k15 long step
Old 11-14-2010, 11:54 AM   #9
rain_man
rain_man's Avatar
Lizard skin is the $hit my buddy has it in his 65 and it makes a huge difference
61 step/long bed SBW(SOLD)
NEED A NEW PROJECT
rain_man is offline   Reply With Quote
Old 11-14-2010, 01:32 PM   #10
raycow
[QUOTE=Born Lucky;4293968]I seem to be getting most of the noise from the engine. I have a 292, 4 speed trans with a Eaton HO52 rear end./QUOTE]
I'm wondering if at least part of your problem is caused by engine rpm. What gears are in the H052 and what tire size are you running?
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 11-14-2010, 01:47 PM   #11
lakeroadster
Are your door seals, window seals - fuzzies and weatherstripping good?
In my experience the most cost effective way to eliminate rattles and noises in an old vehicle is to
1.0 upgrade the stereo and speakers,
2.0 put louder mufflers on.
lakeroadster is offline   Reply With Quote
Old 11-14-2010, 03:30 PM   #12
Born Lucky
Yes I beleive that is the problem RPM's. The engine revs alot doing 60 MPH.
Eaton HO52 is either a 4:11 or 4:56, I beleive.
I just want to listen to music and feel like I am not in a drum.
Old 11-14-2010, 11:43 PM   #13
TwoFiftyShifter
Well, if you drive at 45mph is it any better? If it is, its simply the engine rpms. Your at about 3,000 rpm at 60.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 11-15-2010, 01:57 AM   #14
Captainfab
60-66 Nut
Aside from the engine noise, the SM420's can be a little noisy, and the HO52 can be rather noisy too. I'm thinking you have a combination of everything making noise. Aside from insulation your cab, I would recommend looking into lowering your cruise rpm's. Not only will your engine last longer, but your gas expense will decrease.
Old 11-15-2010, 07:37 AM   #15
Born Lucky
Yes,this is the noise!
If I slow down it goes away or should I say the RPM"s drop and you hear lots less.
I am looking into a rear end change( I would really like to keep original But the gas and noise are getting to be a PAIN)for the coming spring.
Do you think if I sound proof the hood and further sound proof the floor it will GREATLY reduce the noise?
Old 11-15-2010, 05:59 PM   #16
skysoldier173rd
skysoldier173rd's Avatar
Somethin' ain't right here. I can cruise at that speed in my 60, got a 350 with 700r4 windows up or down, headers with 40 series flowmasters and it really isn't bad. I think you must have some kind of vibration issue. I rember having a 90 with a 350 towing a trailer in 3rd gear from Michigan to Florida and the drone about drove me crazy. Something about pitch as compared to volume, two different things.
skysoldier173rd is offline   Reply With Quote
Old 11-15-2010, 06:12 PM   #17
raycow
Originally Posted by skysoldier173rd View Post
got a 350 with 700r4.
That's the secret ingredient. You have overdrive, so your engine is turning 30% slower.
Ray
Old 11-15-2010, 06:37 PM   #18
sandnuriz
sandnuriz's Avatar
X2 on the Lizard Skin http://www.lizardskin.com/
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project)
It's your ride build it the way you want !!!!!!!!!!
sandnuriz is offline   Reply With Quote
Old 11-15-2010, 08:31 PM   #19
Born Lucky
Yes, you have overdrive.
I have a 4:11 or 4:56 gears so if I travel above 55 I get high RPM"s
Old 11-16-2010, 01:57 AM   #20
dan42
dan42's Avatar
I think the tranny noise is an issue as well - I have a 350 with the SM 465 in my '67, with 3:73's, and I have a real noise problem as well, even though I soundproofed the cab and the doors - it is engine/tranny noise, and some wind noise. I'm eventually going to line the hood and see how much difference that makes.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
