Old 11-15-2010, 11:46 AM   #1
NicoSlam
Help with original radio install
So I recently purchased an AM/FM radio from a member a few weeks ago but I'm not sure how it is installed. I have the bracket that mounts to the firewall and holds the speaker but I think there is a rod that goes from this bracket to the back of the radio for rear support but I'm not sure. The reason I think this is true is because the firewall bracket has an extra J-clip. Also, how is the radio attached to the dash? Can anyone provide a good pick of all brackets and there orientation to the firewall and Dash. thanks for everyones support.
NicoSlam is offline   Reply With Quote
Old 11-15-2010, 12:14 PM   #2
KEL
72 GMC
KEL's Avatar
Re: Help with original radio install
take a look around
in the last week, some one posted all this up with pictures
might have been LockDoc
good luck
KEL is offline   Reply With Quote
Old 11-15-2010, 12:42 PM   #3
KEL
72 GMC
KEL's Avatar
and it appears on the top right on queue !!!
http://67-72chevytrucks.com/vboard/s...d.php?t=429841
Old 11-15-2010, 03:48 PM   #4
NicoSlam
Thanks for the lead to the great pics. I am missing the L bracket connecting the back of the radio to the main speaker bracket.
thanks again.
Old 11-15-2010, 04:38 PM   #5
68gmsee
Active Member
68gmsee's Avatar
Should be easy to make if you can't locate one. Local hardware stores carry small strips of sheetmetal or thin galvanized metal. Maybe someone has one laying around to send you the measurements.
68gmsee is offline   Reply With Quote
Old 11-18-2010, 02:48 PM   #6
camrycurt
camrycurt's Avatar
I just used a length of flexible metal plumbing strapping (the metal strip with all the holes) when I installed my stock radio. You can probably even just skip it as the cups that hold the radio posts to the dash provide 95% of the support, but I wasn't sure if the strap was needed for a ground or something like that so I added it just in case.
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 11-18-2010, 04:26 PM   #7
red71c10
The Red Menace
red71c10's Avatar
X2! Metal plumber's tape works great!
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
