Old 11-15-2010, 02:50 PM   #1
timjt
Whats the most horse power you can put into a 85
Whats the most horse power (biggest engine) you can put into an 85 silverado C10 without doing any welding or major mount/frame work? Is the 454 bored out with all the new heades and rockers and all that stuff the best you can do? What problems would I encounter?
timjt is offline   Reply With Quote
Old 11-15-2010, 02:54 PM   #2
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: Whats the most horse power you can put into a 85
This is entirely dependent on how deep your pockets are. Horsepower costs money.....
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 11-15-2010, 03:07 PM   #3
rare86
Extended cab fanatic
rare86's Avatar
i think the GM 572 is a bolt in. Cant swear to it, cant afford one, but Id be willing to bet it is. Horsepower is only limited to your pocket book as stated.
If it has a motor, it has my attention.
rare86 is offline   Reply With Quote
Old 11-15-2010, 03:21 PM   #4
355bullet
355bullet's Avatar
its called Per Cubic Dollars!
hahaha ..depends on your budget....hope this helps you.
here is a link for crate motors. they carry Gm performance also.
You sometimes save money and time with a create motor
my first crate motor for my nova was with these guys, it lasted 13 years.
Ran 14's flat, beat on it...drove it to work, school, clubs, local cruz spots
http://sdparts.com/category/crate-engines-0
http://sdparts.com/category/gm-perfo...p-350ho-engine
355bullet is offline   Reply With Quote
Old 11-15-2010, 03:22 PM   #5
SS Delux
SS Delux's Avatar
what kind of horsepower can you run before you have to start bracing up the frame ?
SS Delux is offline   Reply With Quote
Old 11-15-2010, 03:30 PM   #6
83burban
I think at anything above 500 you will need to address many small issues like upgrading everything to high strength bolts and removing rivets and either welding or bolting on parts- above 750 hundred I would start to brace everything - beyond that I would be going custom frame for safety
83burban is offline   Reply With Quote
Old 11-15-2010, 03:30 PM   #7
Yupiamlo
Yupiamlo's Avatar
The frame wont be as much of a problem as traction... After like 450 to the wheels or so I would think your gonna be spinning everwhere. But my guess before you should box the frame and that kind of thing would be like 700 - 800 but thats a lot... like damn
Yupiamlo is offline   Reply With Quote
Old 11-15-2010, 06:42 PM   #8
mooseknuckles
mooseknuckles's Avatar
I think you'll have to worry about traction, trany's and rear ends first!
mooseknuckles is offline   Reply With Quote
Old 11-15-2010, 07:14 PM   #9
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Throw a 572 in that baby
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 11-15-2010, 07:32 PM   #10
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
You guys are over thinking. Put a stock LS motor with a turbo on it, good suspension and you'll be good to handle 650-700hp all day long.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 11-15-2010, 07:53 PM   #11
iroc12valve
speaking as someone whos delt with many, some up to 600 horse if you drive with all your brain cells the only things you'll blow up were worn out already
these trucks had very strong parts out of the factory the only reason that there are so many that are reduced to scrap is age, abuse, and owners that save money by hillbillying stuff to work. if you had a brand new 1985 c10 that just rolled out of the factory last week and a brand new 2011 silverado and drove them the same the 85 would outlive the 2011.
Just remember when building up a truck that: Quality = FAIR Price
1991 V3500 350TBI/4l80/205 D60/14bff - Crew long
1987 IrocZ-28 525 horse/567 Lb Tq 383
1976 K30 on 39.5s One wheel drive thanks to a np203
and some K5's lol
iroc12valve is offline   Reply With Quote
Old 11-15-2010, 08:34 PM   #12
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
I had a 87 LWB silverado. pulled the 350tbi and stuck a 454 bored out to a 496. professionaly built... costed an arm and a leg, at the time it was the best of the best. built TH400 by a renown shop, and a built ford 9"... should have bought a stall, i used a stock th350. I bought some cheap 25$ nascar slicks from ebay for burnouts, well i used them at the track and they were crap. I knew they would be since they compound was stupid hard. The announcer gave me an applaud for the smoke show. I only took it to the track once, stacked 8 bags of concrete in the bed near the tailgate (seriously 8) and ran a 13.0 at 114mph. had i not had that extra couple hundred lbs, it would have been 11's... but thats numbers. I had no suspension work done at all, no boxing of the frame, but I didnt do anything stuid like autox or constant drag racing.... awesome truck though
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
Last edited by Sillyoldman; 11-15-2010 at 10:38 PM. Reason: Removed verbage which offended another member.
87chevy.com is offline   Reply With Quote
Old 11-15-2010, 08:37 PM   #13
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Install a 500 Caddy!! More power and torque than a 454. Less weight and better gas milage!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 11-15-2010, 09:11 PM   #14
3r!c84
Badass
3r!c84's Avatar
no replacement to replacement
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-15-2010, 09:18 PM   #15
Ceeten
This
Ceeten is offline   Reply With Quote
Old 11-15-2010, 09:44 PM   #16
timjt
Thanks! Got alot of good ideas now. I would like to keep the body and frame as stock as I can, right now I'm getting my 700r4 working then a new paint job and window rubber (its really falling out) and then the motor. Probably end of next year, but I want to start looking now and seeing what I'm dealing with.
If the engine has not been rebuilt (as far as I know and its an 85) then what should I replace/fix/upgrade before putting a turbo on it? (and are you recomending that with a 454 or my original 305?)
Old 11-15-2010, 10:25 PM   #17
thirdstreettito
Resident of Here
thirdstreettito's Avatar
A stock 700R4 will only handle 300hp max.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 11-15-2010, 10:30 PM   #18
timjt
I'd like 300 haha.
What needs to be done to the transmission or what transmission do you need then? I'm really new to trucks (or mechanics in general) I thought the 700r4 was one of the bigger better transmissions...? wasn't that whats in the old camaros? and for the record is there a difference between the 700r and the 700r4? or just lazy typers?
Old 11-15-2010, 10:40 PM   #19
thirdstreettito
Resident of Here
TH700R4, TH700, 700R, 700R4, all the same, 700R4 is the main name for it. It was is multiple cars, it is a 3-speed automatic with overdrive, which makes it a 4-speed automatic. A race trans builder can build you one, or you can order a built one online.
http://www.transmissioncenter.net/700MegaRaptor.htm
http://racetransmissions.com/store/i.../cPath/1_25_56
~Bradley~
Miss having a truck
Old 11-15-2010, 11:17 PM   #20
bitchin85
bitchin85's Avatar
u mean displacement? lol
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 11-16-2010, 12:23 AM   #21
3r!c84
Badass
3r!c84's Avatar
haha my bad!!! didnt see that
-00 Saturn 5spd
1/4:13:90
