11-15-2010, 04:45 PM | #1 |
I built it
locked hubs on freeway?
as you know, the bad weather season is coming. im wondering if its ok to keep the hubs locked with the x-fer case in 2wd while going 60mph? (info is for truck in sig.) will it hurt anything doing this? axle bearings, u joints, etc.?
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
11-15-2010, 05:17 PM | #2 |
Re: locked hubs on freeway?
No, it wont hurt a thing. If you really have a 203 t-case, you shouldn't even have lockouts.
Tim |
11-15-2010, 05:19 PM | #3 |
On all my older manual hub vehicles that were daily drivers I used to lock the hubs at the beginning of winter and unlocked them in the spring. You could possibly wear some parts faster? I always kept my stuff maintaned and never had a problem. Someone else may have a different opinion?
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
11-15-2010, 05:22 PM | #4 |
6>8 Plugless........
The only thing it will hurt is fuel mileage. If you have a NP203, hopefully someone has installed the part time kit in it so your drive line doesn't spin with the hubs unlocked. Since you plan on running the lock outs locked in, just double check all of your fluids to make sure they are full and not full of debris, or really old. You also might give your u-joints a once over to make sure there aren't any loose ones or anything strange. With the lock outs locked in during normal driving every day, you could start to see wear in these items fast because they aren't used to be turning a lot every day. Not really a big deal. Some of the newer trucks front drive lines are turning all the time, Dodges mainly 02 and up.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-15-2010, 05:24 PM | #5 | ||
I built it
11-15-2010, 05:29 PM | #6 | |
I built it
11-15-2010, 07:35 PM | #7 |
The original T-case in a '72 would be a 205. But running with the hubs locked and the shifter in 2 hi shouldn't be a problem. My Jimmy cratered the rearend nearly 30 years ago, and my dad drove it in front wheel drive for at least 6 months. Just pulled the driveshaft and kept on going until he had a replacement.
11-15-2010, 08:07 PM | #8 | |
Your signature says Dana44 frt "factory locker".....I find that very hard to believe, especially with a 12 bolt and a clutch-type Posi in the rear.
What kind of differential is really in there? If it really does have a true "Locker", as in Detroit (No-Spin), I would not run it with the hubs locked in in the road. Buy running it w/o power coming to the gears from the driveshaft, it will "annoy the heck out of it". It would be clunking back and forth constantly. Every turn of the steering wheel would have it disengauging from one side to the other.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
11-15-2010, 10:03 PM | #9 |
I agree with MikeC, My 72 has a NP205,
This is a pic of the NP205, look at the small plate in the center with the 3 bolts in it, the 203 is different, just crawl under and have a look. http://media.photobucket.com/image/n...luck75/238.jpg NP203: http://www.hotrodders.com/forum/atta...?postid=297530
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-15-2010, 10:43 PM | #10 |
GM didn't put lockers in fronts of 4wds,or rears of 1/2s at all.We need accurate into to answer the question.It doesn't hurt to leave hubs locked in if it isn't a locker.People only run lockers in the front of off road only rigs.And,even then,most don't.
11-15-2010, 10:44 PM | #11 | |
I built it
11-15-2010, 10:49 PM | #12 | |
I built it
11-15-2010, 11:21 PM | #13 | |
My truck is a 350/350 and has the 205. It also used to be the same color as yours so i'm a bit jelious, my step dad payed my uncle to paint it, he only painted the outside and not the inside, i hate half done paint jobs.
11-15-2010, 11:49 PM | #14 | |
I built it
yea its a great color, all the girls love it! but mine only looks good from about 20ft away though its got runs in the paint everywhere, couple rust spots.. and the passenger side has black primer all over it
11-15-2010, 11:51 PM | #15 |
20' Daredevil (Ret)
My '72 is also 350/350/205. More than 30 years ago I drove it through winter storms from N. Calif. to Kansas, and the hubs were locked in for hundreds of miles as I went in & out of 4WD. No issues then, in fact still no issues.
Well, I did replace the double cardan joints on the front driveshaft a few years back, but that's about it.... and they were original, so I got my money's worth out of them.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
11-16-2010, 12:58 AM | #16 |
Ok so i'm not so jelious now i guess..
11-16-2010, 01:42 AM | #17 |
BlahBlahBlah
I had no idea it was OK to run like this. Even though Ive had 4X4 Chevy trucks for at least the last 15 years I really don't know much about how the drive train works.
I'm not an avid four wheeler, I just like the extra pull when I need it. Definitely gotten me out of a jam more than once.
11-16-2010, 08:52 AM | #18 |
The original design for this type of 4wd was always locked in.Hubs to disengage for free wheeling were an after thought first made by the aftermarket.That's why they are called lock out hubs (or at least were for a few decades).There are listed as an option.U-joints,dbl cardons,and hubs wear out from lack of use...lube isn't spread around.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 11-16-2010 at 08:54 AM. |
11-16-2010, 01:05 PM | #19 | |
BlahBlahBlah
11-16-2010, 03:06 PM | #20 |
I built it
11-16-2010, 03:40 PM | #21 |
I built it
ok from the pics that swamp rat posted it IS a 205. i never knew how to tell haha. just took it for a drive around the block with the hubs locked and no noise. checked 4hi and low and both work properly. thanks all for all the help!
11-16-2010, 08:39 PM | #22 |
In the owners manual it actually says to lock in the hubs while in 2wd from time to time to ensure front end lubrication.
11-16-2010, 08:46 PM | #23 |
Registered Chevy Owner
this is good to know I was thinking about this a while ago. I didn't want to have to get in and out to lock and unlock my hubs. Thanks for all the info.
Love is fleeting, but Chevy trucks are forever!!!! 1970 Chevy CST C10 long box 350/400 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
11-17-2010, 04:14 AM | #24 | |
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
11-17-2010, 08:03 AM | #25 |
No.The whole idea of hubs in "Free" is to disengage from the axle.The point is to spread the lube in the outer hubs around,so the hubs need to be engaged.
