11-17-2010, 09:21 AM | #1 |
Project Heaven in my 67!!!
Changing 1/2 ton 2wd to 1 ton 4X4
How hard would it be to change a 68 1/2 ton 2WD to a 3/4 or 1 ton 4X4??? Anyone know? Has anyone done the change before?
11-17-2010, 09:24 AM | #2 |
Re: Changing 1/2 ton 2wd to 1 ton 4X4
If you could get the whole frame and running gear it would pretty easy... or are you looking to put the 4wd suspension set up under the 1/2 ton 2wd frame?
69 Chevy C10 88 Sierra 02 2500 Suburban And too many S10s to list! |
11-17-2010, 09:25 AM | #3 | |
I was hoping to use the original frame because it is a 50th 68! I really want to use as much of the 68 as I can! |
11-17-2010, 10:05 AM | #4 |
The General never made a 1-ton 4x4 in the 67-72 body style.
What I would do is get a 71 or 72 3/4 ton frame and put your 68 body on it. 71 or 72 gets you disk brakes and commonality through 1987. You could then get a newer (through 87) 1-ton front and rear and swap them in for a 1-ton.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
11-17-2010, 11:04 AM | #5 |
Here is mine. It has the Dana 44 from a 72 K5 and the 14 bolt rear from a 73 one ton. I went with a t400, 208 transfer and a gear vendor OD. It has one ton drive shafts with CV joints by High Angle Driveline The frame is the original 69 1/2 ton 4x4 which I beefed up in key spots The cab came from a 69 CST. The truck took a year and a half to build in honer of my wife who always called it the million dollar truck.
69 Chevy 4x4 383 Power |
11-17-2010, 11:13 AM | #6 | |
11-17-2010, 11:16 AM | #7 |
Sadly I did not have a digital camera at the time so most of my pictures are in a album. I need to get them put on a CD. There are a few in my profile.
11-17-2010, 01:05 PM | #8 |
OK, so if I found the 4X4 suspension for a 3/4 ton truck, would it bolt directly to the 1/2 ton 2wd frame???
11-17-2010, 01:10 PM | #9 |
Yes the springs will mount to the frame in the original brackets
10-26-2011, 11:51 PM | #10 |
OK, Decided to go a different route for this build and go with 3/4 or 1 ton 2WD...but, same question applies...
Anyone know what the differences are in the suspension setup as far as how it is bolted to the frame? Could I take the suspension off of a 3/4 or 1 ton truck and bolt it directly to a 1/2 ton frame? |
10-27-2011, 08:48 AM | #11 |
is your 2wd truck a coil spring rear or a leaf spring rear?
James 94' Chevy K1500 Extended Cab 4x4 5.7 72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver" |
10-27-2011, 11:29 AM | #12 |
It is a coil spring rear!
