11-19-2010, 03:06 AM | #1 |
need help with front a rear bags??
need help on getting the right bags for my truck
the truck with have a 3in zed front frame will also have cupped LCA the rear will be 4 linked with a 13in c notch. the rims will be 22in KMC RockStars.. any imputs? |
11-19-2010, 03:09 AM | #2 |
Re: need help with front a rear bags??
forgot to mention it will also have 2 !/2 drop spindles
11-19-2010, 11:16 AM | #3 |
Where do you plan to put the rear bag mounts as that impacts answers? The front would use a standard 7" dbl convoluted bag. Firestones & Slams up front seem to be the 'go-to' choices.
11-20-2010, 06:40 AM | #4 |
Thanks man. The rear bags will me mounted in front of the rear axle.
Posted via Mobile Device |
11-20-2010, 09:30 AM | #5 |
On the actual axle housing or on the link bars? On the actual housing would be better suited w/a tapered/rolling sleeve style bag; if locating them on the bars, dbl convoluted.
11-20-2010, 11:49 AM | #6 |
Don't rule out Dominators for the front bags
11-20-2010, 12:03 PM | #7 |
Chevy Only Tx
Post up pics of your truck as it sits now
Chevy Only Tx......... |
11-22-2010, 06:43 PM | #8 |
I will post pics when I get the frame home, won't be till the end of December. As the frame sits now it's all stock, I'm gathering the parts to get the frame set up to lay on the ground. I was thinking zed front frame but not Sure how tall to get the bags. Also not sure how tall to get the rear bags. The bags would be mounted on the housing.... Thanks for all the imputes an help guys!!!!
