Old 11-19-2010, 02:50 PM   #1
mikemileski
Another HVAC Question
My truck is a '72 GMC 4x4 with factory AC. Right now the vacuum hose that leads to the heater control valve has vacuum to it all the time, regardless of whether the control lever is moved to the hot or cold position. The heater valve that's on there now is the type that's open when no vacuum is applied, which means it's closed continuously for me because my system is applying vacuum to it at all times. Does this mean that my vacuum switch is malfunctioning? I have a two port system and the vacuum hoses are plumbed exactly as the diagram for the two port system shows in the service manual. If the control head vacuum switch is bad, is it a separate piece or would I need to buy the entire assembly (and, if so, who makes something that's a higher quality than some of the cheapo replacements I've read about)? Also, is there anybody in Tucson that has some knowledge and experience with this?
Mike Mileski
Tucson, AZ
mikemileski is offline   Reply With Quote
Old 11-19-2010, 08:59 PM   #2
sporty1200xlc
sporty1200xlc's Avatar
Re: Another HVAC Question
Interesting I have the same problem. Just havent really checked into it yet. Maybe you will get it. Good luck.
sporty1200xlc is offline   Reply With Quote
Old 11-19-2010, 09:47 PM   #3
nyncompute
nyncompute's Avatar
I've had to replace the vacuum switch behind the control head myself. A couple of screws hold it on. I'm sure if you suspect a damaged one (mine had an audible leak) someone on the board will sell you one. I now keep a spare myself. Hope that addresses part of your question.
1972 K-10 SWB Cheyenne
nyncompute is offline   Reply With Quote
Old 11-20-2010, 06:31 PM   #4
mikemileski
No audible or obvious leaks, just full-time vacuum to the heater valve.
Mike Mileski
Tucson, AZ
Old 11-20-2010, 06:36 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
FWIW, when I was working at a Sears auto center, a customer came in with a heater problem, in his FoMoCo vehicle. Upon doing some checking, there was coolant in the vacuum lines to the control ass'y.
I don't recall that any GM product I've ever seen had that problem.
We didn't work on it, so I don't know what the problem was.
Member Nr. 2770
Old 01-04-2017, 01:45 AM   #6
glord
glord's Avatar
Hello Mike, did you ever solve your issue. I have exactly the same problem and came to the same conclusion that it may be the Vacuum Control switch. However the entire heater control unit appears to have been recently replaced.
Thank you
glord is offline   Reply With Quote
Old 01-04-2017, 01:04 PM   #7
Andy4639
Old member
Andy4639's Avatar
Talking Re: Another HVAC Question
1 thing some over look.
The vacuum port on the valves are different from model to model. They could have bought a vacuum port for a different model that closes it when vacuum is applied instead of opening it.
Just like the kick panel on the truck is opposite of the water valve.
You cant mix and match them up.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-04-2017, 09:09 PM   #8
glord
glord's Avatar
Thank you Mike. Understood in terms of the heater bypass valve. However my understanding is the system should only be under vacuum when air conditioner is on.
Old 01-04-2017, 10:31 PM   #9
hdff
hdff's Avatar
FWIW this thread is 6 years old and mikemileski has not signed on since 2013, although andy4639's info is correct
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 01-04-2017, 11:15 PM   #10
glord
glord's Avatar
