Old 11-19-2010, 05:55 PM   #1
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
6.2 Diesel
how hard is this swap? i found one in a local bone yard....
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 11-19-2010, 06:43 PM   #2
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: 6.2 Diesle
Get it! It would be fun!
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 11-19-2010, 08:33 PM   #3
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: 6.2 Diesle
Whats more fun is the price i would pay for it :P but what do i need to get from the Doner truck?
Old 11-19-2010, 08:56 PM   #4
swampfox
swampfox's Avatar
Re: 6.2 Diesle
If your truck and the donor truck are close to the same age it shouldn't be to bad . You will need all the wiring system for the glow plugs ,radiator ,starter, set up for duel batteries.It would be good if you could get the whole truck and return what is not needed. I have went from 6.2 to a 350 years ago but not the other way.
69 gmc 4x4 lwb 327 4sd not running
swampfox is offline   Reply With Quote
Old 11-20-2010, 08:34 AM   #5
D13
D13's Avatar
Re: 6.2 Diesle
6.2 is in the jyard because it's broke. Leave it there.
If you really want to do the swap, it depends on what you want factory and what you want to work. Best bet is to get the WHOLE TRUCK because a lot of the parts are unique.
1. Tanks MUST have a return line. You'll need to purge your tank of all gas and make sure all lines are clean.
2. Motor mounts are different.
3. Diesels make almost no vaccuum. Therefore they hae a vacuum pump that is used to provide vacuum for heater doors, trans, etc. This will not safely run a brake booster so diesels use hydro boost brakes which requires a different power steering pump reservoir, and brake booster set up.
4. Trans control is different. TH400 uses a vacuum controller on the injection pump, TH700R4 uses a throttle position switch on the IP plus a TV cable with a diesel unique rod. TH350 was never offered.
5. If you live in a warm climate or tow you'll need a BIG radiator or a lot of fans. The diesel shrouds are different.
6. 2 big batteries required (900CCA's min) and high output alternator (like 135A min).
7. Fuel filter - probably has the firewall mounted box. You'll need it.
8. All brackets, accesories, etc are unique to the 6.2.
9. Dashes and underdash wiring are diesel unique although you could just bypass some of that.
10. Glow plug control, either facotry or a Ferd startr relay and a button.
That's what comes to the top of my head....
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 11-20-2010, 09:03 AM   #6
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: 6.2 Diesle
Oh the only good thing about my truck is i have hydro boost brake set up. actually a buddy and i were tlaking prob better to get a newer style motor. 6.5 6.6?
