Old 11-20-2010, 02:06 PM   #1
Fesser
Fesser's Avatar
Blazer fender on a SWB fleet?
I've been searching on here but haven't found what I'm looking for. I have a 72 SWB fleetside and a 72 Blazer parts truck. My fleetside's drivers bedside is mangled all around the taillight and part way to the fender opening. The blazer's fender is nearly perfect. Sooo, I started thinking, what if I cut the outer skin of the fleetside fender from the center of the wheelwell back and replaced it with the section from the balzer. I could also swap the blazer tank and filler assembly at the same time and solve two issues at once. I'm sure this has been done but I haven't found any links. Any reason to think it won't work?
Fesser is offline   Reply With Quote
Old 11-20-2010, 02:57 PM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: Blazer fender on a SWB fleet?
As long as you're comfortable cutting and welding the sheet metal I say go for it.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 11-20-2010, 05:32 PM   #3
cdowns
cdowns's Avatar
measure b4 cutting
Old 11-20-2010, 11:59 PM   #4
Fesser
Fesser's Avatar
Any braces or structures between the inner and outer bed walls that I want to look out for, or aim for?
Old 11-21-2010, 01:46 AM   #5
RED72blazer
urban fourwheelin
RED72blazer's Avatar
I'd sell that blazer quarter and buy a long bed to cut up. Blazer stuff doesn't grow on trees.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
