11-21-2010, 06:25 AM | #26 |
Re: parting 67-72 chevy parts trucks
How about front leaf spring hangers from a 2-wheel drive 1/2 ton?
11-21-2010, 07:43 PM | #27 |
Thanks. If the rims are what I am looking for I will give you a price that I am willing to pay for everything that I listed.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends. '72 blazer 2wd build 67-72 Factory Big Block Registry |
11-21-2010, 08:01 PM | #28 |
What is your price for the heater controls and screws (if you find some)?
11-21-2010, 08:20 PM | #29 |
Any 8 lug steel rims 16X6?
1971 C20 LWB Cheyenne 396/TH400 2017 Chevy SS - Holden conversion 2015 Chevy SS 2013 Acura MDX |
11-22-2010, 12:18 AM | #30 |
I am interested in the spark plug wire brackets that bot to each side of the intake manifold, and to the back side of each head, as well as the four spark plug heat shields on the engine in the first photo, shipped to Lolita, TX 78641.
11-22-2010, 05:01 AM | #31 |
how much for this bracket off the the brake booster to the brake pedal? thanks
11-22-2010, 05:05 AM | #32 |
also need a good throttle cable and bracket that goes on the intake. thanks
11-22-2010, 08:33 AM | #33 |
copuld use the manifolds if avail.
11-22-2010, 11:22 PM | #34 |
Junior Member
how about power steering gearbox and power steering pump with all mounting brackets for sbc shipped to 29702,,,thanks
Sorry no.
1970 1/2 ton swb |
11-22-2010, 11:41 PM | #35 |
Junior Member
I have a heater control and cables. no broken levers. hows $45 shipped. I'll have to see if its in good shape. I'll check as soon as I can. thanks rio
1970 1/2 ton swb |
11-22-2010, 11:46 PM | #36 |
Junior Member
everyone I'll check as soon as I can.
Thanks Rio
1970 1/2 ton swb |
11-23-2010, 07:43 AM | #37 |
I need the fresh air valve that is located inside the cowl on the passenger side on the AC trucks. There is a plastic bolt that comes into the cab right behind the glove box. I broke that plastic nut and bolt. I need that nut adn bolt and I assume the bracket and flapper(door) that it is connected to. Thanks.
Jeremy (NUBOMB) 72K5 CST 350/350/205 1951 Chevy 1/2 ton North Georgia Group "... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman. |
11-23-2010, 10:51 AM | #38 |
Do you have any transmission lines for a 350 automatic ? Price plus shipping to zip 32136. Thanks
11-23-2010, 10:57 AM | #39 |
I can pickup and will probably find some other parts I can use.
11-23-2010, 11:01 AM | #40 |
$45.00 shipped for the heater control and cables sounds good. Cosmetics aren't that important (you should see the mess its going into) as long as the levers are there and everything slides. Let me know where and how to send funds. Its getting colder.
11-23-2010, 02:05 PM | #41 |
Do you have a jack, jack handle and tire iron for a 1972 C10?
What about an auxilary battery tray? Both need to be in good condition. |
11-23-2010, 02:35 PM | #42 |
Got a complete heater/AC controls? Umm the deally bob under the radio, the whole thing.
72 CST Blazer 4x4 (Revival in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=430968 |
11-23-2010, 06:37 PM | #43 |
member
69 4x4 rear driveshaft? Thanks
John
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
11-24-2010, 12:22 AM | #44 |
Junior Member
pic of ashtrays
blue ashtray $15 shipped
1970 1/2 ton swb |
11-24-2010, 12:40 AM | #45 |
Junior Member
How about the exhaust manifold shield with tube and the top alternator bracket. shipped to 90277
I have the tube and the top alternator bracket. hows $38 shipped. are make me a offer the exhaust manifold shield is no good.
1970 1/2 ton swb |
11-24-2010, 12:45 AM | #46 |
Junior Member
How about a working heater control setup (without AC) that would work in a 72 ...and the screws that go through the top of the inside of the door into the bottom of the wing window on the 72 (there is one on each side)...and the little plastic things the screws go through if it has those (might only be on Blazers, I don't know). To 94559
sorry the heater control setup and the screws are no good. Rio
1970 1/2 ton swb |
11-24-2010, 12:46 AM | #47 |
Junior Member
John sorry no.
1970 1/2 ton swb |
11-24-2010, 12:47 AM | #48 |
Junior Member
sorry no. rio
1970 1/2 ton swb |
11-24-2010, 12:57 AM | #49 |
Junior Member
$25 shipped on the 350 Fender Emblems.
1970 1/2 ton swb Last edited by rio; 11-24-2010 at 12:58 AM. |
11-24-2010, 08:09 PM | #50 |
any news on the parts i asked for thanks
