Old 11-21-2010, 06:34 PM   #1
CVA59
Power Steering Question
Hey guys, I have a all original 283 with the original heads (no holes). I am looking to adapt a power steering pump to this motor and eventually an AC compressor. What are you guys doing as far as brackets on motors like mine with no holes in the front of the heads?
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline   Reply With Quote
Old 11-21-2010, 06:54 PM   #2
DPowers
One foot in front of the other
DPowers's Avatar
Re: Power Steering Question
SWP PS setup- off of the engine mount and lower block.
You could have the heads drilled and tapped.
A/C was an option, so there has to be some way to mount the A/C.
or- you could put a set of 305 HO heads on it... heard that it is a good fit- want to try it on the next one.
DPowers is offline   Reply With Quote
Old 11-21-2010, 07:13 PM   #3
Rich 5150 69
Rich 5150 69's Avatar
Do a google search for pics...http://www.google.com/images?client=...w=1226&bih=606
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 11-22-2010, 02:03 AM   #4
Captainfab
60-66 Nut
Pretty much any pre-68 passenger car small block power steering pump assembly will work. Probably the easiest power steering bracket to find for a small block with a short water pump is for the '69-'72 pickup. There were a couple variations, but they all bolt to the front of the block and over to the one motor mount bolt. They can be found here in the '67-'72 classifieds and on ebay both used and repro. That is if you can't find anything locally.
Old 11-22-2010, 07:23 AM   #5
1restorick
1restorick's Avatar
The automotive aftermarket also has you covered on this. March Performance makes a nice Power Steering Pump Mounting Bracket:
http://www.summitracing.com/parts/MCH-20112/
You could also look at the steel brackets offered by Alan Grove:
http://www.alangrovecomponents.com/
Sincerely,
Rick
RED RUMBLE
1963 C10 Chevy Truck
Owned since 1984
1restorick is offline   Reply With Quote
Old 11-22-2010, 09:37 AM   #6
CVA59
Thanks for all the info guys. I am sure i will be able to come up with something from the resources you have provided.
Zack
www.23t.weebly.com
