Old 11-22-2010, 09:07 PM   #1
masterlock
masterlock's Avatar
Question Cab differences???
What are the differences between a cab for a 77 C10 and an 88 C10. The cab on my 77 was rotted out and the shop where it is wants to replace it with an 88. The cab looks almost identical as far as the the basic sheetmetal, My only concern is when it comes to all the interior stuff i.e. the dash and gauge cluster will it fit? Just looking for some reassurance that it will all work out for me without having to buy a whole new dash and so on.
masterlock is offline   Reply With Quote
Old 11-22-2010, 09:57 PM   #2
f.monroe
f.monroe's Avatar
Re: Cab differences???
That stuff will fit . The seat belts wont bolt directly in . They changed the mounting points and angles in 78 . The 81 and up cab will have the provisions for later style hood hinges. No problem since you wont be using them .There may be other differences but they are all minor . It should work with a little modification.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 11-23-2010, 04:52 AM   #3
80stepsideguy
Laid back freak
80stepsideguy's Avatar
88 c10 is a totally different truck. I think you better check with this guy before you do any kind of cab swap.87 was the last year for the c10 IIRC on the body, they did have the square body for the blazers and suburbans 88-91.
thanks
pat
1980 chevy c10 step side restomod,
1970 cougar convertible 1 OF 24 ever built:
2014 Hyundai Tucson limited (daily driver).
80stepsideguy is offline   Reply With Quote
Old 11-23-2010, 06:53 AM   #4
GM72K10
Next!
GM72K10's Avatar
thanks
pat
They also had square body cabs for 88-89 C30 cab and chassis, called R30/V30
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 11-23-2010, 09:07 AM   #5
babyJay
Arrived on a Pale Horse
babyJay's Avatar
If it's truly an 88 half ton, the sheetmetal can't look identical. And what do you mean by "almost"? Also, GM didn't make an 88 C10, in 87 they became R/V series trucks. One of my 87's is a V30 (4 wheel drive) and one is an R30 (two wheel drive).
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 11-23-2010, 09:14 AM   #6
ont_guy_38
ont_guy_38's Avatar
He says the cab looks almost identical so I'm thinking he meant to type 87 not 88
ont_guy_38 is offline   Reply With Quote
Old 11-23-2010, 12:36 PM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
if hes using your old doors with the new cab it will line up and work fine.... if he uses your old dash pad youll never know the difference ont he dash... the only mods i see happening if you have a stick and the other is automatic or if one has heat and the other AC
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-23-2010, 01:11 PM   #8
masterlock
masterlock's Avatar
Thanks for the reassurance guys. Whether it is called a C10 R10 or X10 i just wanted to know that it should all work out and it looks like that is the consensus. Besides the seatbelt mounting location there were no differences that I could see but this is my first truck project so I just wanted a second opinion.
Old 11-23-2010, 01:27 PM   #9
benoit454
Chris
benoit454's Avatar
the wiper linkage is completely different, the holes are not lined up the new cab would need holes drilled and filled to make the older wiper linkage work, not to mention the hood hinge holes cut into the cab that would need filled. If you do a 81-87 front clip change then it would be no problem just use the 81-87 linkage. Not sure if the motors are different or not but another problem is the dash part, the switch for them is on the dash of the old trucks and new trucks its in the column. Not sure how that one would work out. Maybe you can use yours bezel on the newer pad? or use your pad and bezel. The door panels don't line up too great without the right dash either. meaning again 81-87 door panels and dash, or 73-80 dash and door panels. a/c or not effec ts dash and bezel. alot of small things.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 11-23-2010, 01:45 PM   #10
masterlock
masterlock's Avatar
Not too concerned with having to patch up holes on the cab. Im already patching up the holes from the A/C and other misc. holes that are unneeded. As for the dash Im keeping my 77 dash, bezel and cluster and am using the doors from my original cab. The wiper linkage Ill have to look at.
Old 11-23-2010, 02:04 PM   #11
Jonboy
Slots go on anything!
84-up have the wipers on the column, vs. on the dash, and the light switch was moved up. Not a big deal, but the dash bezel will not work.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 11-23-2010, 04:17 PM   #12
big_b
the front fender does not bolt up correctly. if you look at the old cab and the new cab at the upper cowl mount, youll notice its different. older style fenders mount differently at the top mount. its about a 1/2" difference.
big_b is offline   Reply With Quote
Old 11-23-2010, 05:24 PM   #13
benoit454
Chris
benoit454's Avatar
hmm ppl have put the 73-80 front ends on the 81-87 trucks never heard of there being a problem bolting them up. As for your dash and doors good choice, I lke them alot better and would make it easier for you too.
Chris
GIT R DONE!!!!!!
Old 11-23-2010, 06:09 PM   #14
GM72K10
Next!
GM72K10's Avatar
not to be a wise guy Bob but 81-87 dash pads do not work in 73-80 trucks and vice versa
86 K30 CUCV M1028A1
Old 11-23-2010, 06:15 PM   #15
big_b
well maybe im full of **** or i have the only '83 cab thats different?
im doing a cab swap from a '79 to an '83. i tried bolting my '79 front fenders to the '83 cab and the top mount hole on the cowl did not line up. that mount affects your hood gap and lining the fender up flush with the doors. my '83 cowl did not have the ear that sticks off the top that the fender bolts to that the 79's have. maybe people just hog the holes out so they line up and dont think anything of it???
the other difference is the cowls with the hood hinges in them do not have the rear hood support that the '73-'80s have. (the support that keeps the back of the hood flush with the top of the fender.
Old 11-23-2010, 09:01 PM   #16
masterlock
masterlock's Avatar
I guess I am just gonna have to go for it. It would cost me more in labor to replace the whole floor as opposed to replacing the cab. I guess I will have to report back to let everyone know how it all fits Ill be pretty disappointed if the 77 dashpad didn't fit.
Old 11-23-2010, 10:19 PM   #17
old Rusty C10
years back i had the 81 cab i put on the 76 frame and the dash pad worked fine.... Im pretty sure i laid the newer dash pad on the old cab when i sent it to the boneyard.... i do know there is the issue with the VIN tag
Bob
I hate cancer!!
Old 11-23-2010, 10:26 PM   #18
bigblock73
yeller
bigblock73's Avatar
Year matters when you ask for help with no pictures. We all know there is no such thing as a 88 C10, but didn't know if YOU did...so they were trying to clarify in order to give you the best most accurate help.
bigblock73 is offline   Reply With Quote
Old 11-23-2010, 10:27 PM   #19
bigblock73
yeller
bigblock73's Avatar
Not true, had a 81+ pad in my 73..fit fine. The only real problem is for the guys with 79-80s as their VIN is on the dash as opposed to the door pillar like the earlier models.
Old 11-23-2010, 10:51 PM   #20
GM72K10
Next!
GM72K10's Avatar
Originally Posted by bigblock73 View Post
Not true, had a 81+ pad in my 73..fit fine. The only real problem is for the guys with 78-80s as their VIN is on the dash as opposed to the door pillar like the earlier models.
well then I would say that is a fitting problem lol
86 K30 CUCV M1028A1
Old 11-23-2010, 11:50 PM   #21
motornut
78K & 79C Jimmys
motornut's Avatar
my 78 the vin is on the door(pillar,jam)
the pad from my 89 sub fits no probs in the 78(had to remove one slide in clip,hit the dash vin)
either door panels fit fine with either dash pad
i think there was a gap with old dash pad and new bezel
wipers and light switch move
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 11-24-2010, 12:06 AM   #22
bigblock73
yeller
bigblock73's Avatar
no, not on my 73...VIN is on the jamb...dash fit perfect.
For the OP, the dash in his 78 won't work right in the "88"...I was just correcting the blanket statement about dashes not swapping period.
Old 11-24-2010, 01:20 AM   #23
junkmen
junkmen's Avatar
hey masterlock I'm putting 81-87 cab on a 73-80 frame using the mounts from your 77 cab it should bolt right on if you use the 87 front clip you will have to move the core support mounts as for the dash i don't know
also 87 and 88 cabs are totally different in the 1/2 tone RC PU unless a 87 was sold in 88
I have a 73 - 75 cab needs a new home
good luck JM
junkmen is offline   Reply With Quote
Old 11-24-2010, 03:02 AM   #24
masterlock
masterlock's Avatar
Ill be honest guys maybe it is an 87. To my understanding it is an identical cab minus the hood attachment. I will have pictures of it soon so everyone can get a good look.
Old 11-24-2010, 12:28 PM   #25
babyJay
babyJay's Avatar
That's good to hear because if it is an 87, then that makes everything a whole lot different. Keep us posted.
Jason
89 R3500 CC SRW
