Old 11-24-2010, 08:10 AM   #1
kikkegek
kikkegek's Avatar
Can I remove this can?
I have removed all the smog stuff from my truck, but have this one canister left.
I can see that the can (in the red cirkel) is still connected to one of the vacuum connections on my carb. What does it do and can I loose it and close the connection on the carb and remove the canister?
i seems to have a line running to the bback of the car, that I havent traced completely to the back yet.
Can I remove it and close the vacuum connection on the carb?
kikkegek is offline   Reply With Quote
Old 11-24-2010, 09:45 AM   #2
monza1979
monza1979's Avatar
Re: Can I remove this can?
yes, the line that goes to the back goes to the fuel tank. just gas fume recirculation canister.
I had the right to remain silent, but i didn't have the ability!
78 chevy swb 4x4 sm465 np205 350 4" lift, ORD flip kit, ORD Ext. brake lines
79 Chevy Monza:current plans, dz 302, 4 speed
69 Pontiac Firebird: 74 s.d. 455 build up, m22 rock crusher
monza1979 is offline   Reply With Quote
Old 11-24-2010, 09:56 AM   #3
3r!c84
Badass
3r!c84's Avatar
How will it vent the gas then?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-24-2010, 09:57 AM   #4
timjt
If I was taking out all the smog I probably would have taken that out first because I like working with my foot where the can goes
Just make sure to plug that carb, runs pretty rough (if at all, depends on how decent everything else is running)
2001 silverado stolen by family
1983 short n wide custom deluxe SOLD
1985 silverado longbed 305 engine 700r4
OH NO! NOT ANOTHER LEARNING EXPERIENCE!!!
"Just because you can do it, doesn't mean that you should"
timjt is offline   Reply With Quote
Old 11-24-2010, 11:09 AM   #5
baclay9
It all depends on how strict your smog laws are over there. If you have to go in for yearly inspections then I would say no. But if it is like it is here in Oklahoma rip it out. We don't have inspections.
baclay9 is offline   Reply With Quote
Old 11-24-2010, 11:21 AM   #6
72lb4x4
Another way of looking at it is why remove it? It has zero impact on performance and reduces emissions so why take it out?
72lb4x4 is offline   Reply With Quote
Old 11-24-2010, 11:27 AM   #7
benoit454
Chris
benoit454's Avatar
cleans it up underhood alot and makes it look better, not to mention it can mess up and not work. Or you'll need some new filter and have to buy it.
You need to leave the vent line going to it from the tank open or put on a breather/filter on the end of it or get a vented gas cap?
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 11-24-2010, 12:02 PM   #8
kikkegek
kikkegek's Avatar
I dont think it is connected to the gastank at all anymore, because I have a brand new custom 20 liter reserve tank and replaced the original with LPG.
LPG price in Netherlands: 0,60 Eur / liter
gas price in Netherlands: 1,50 Eur / liter
easy picking!
Old 11-24-2010, 12:24 PM   #9
benoit454
Chris
benoit454's Avatar
well definately sounds like it could be removed then LOL.
Chris
GIT R DONE!!!!!!
Old 11-24-2010, 02:19 PM   #10
timjt
Old 11-24-2010, 02:21 PM   #11
kikkegek
kikkegek's Avatar
consider it done!
Would be nice to have a place to put my foot when doing stuff to the engine. I am 6,13foot (1,87m) but still it is hard to work the engine and I need a little stool to help me get to certain parts in the engine compartment.
the car is getting spayed with Fluid-Film for corrosion prevention. They use salt in wintertime over here when frost is in the air and snow or ice is on the roads. Killer for old cars like our Burb...
When its back, I'll take it out.
thanks guys!
Old 11-24-2010, 02:24 PM   #12
Dru
Thats about 10 lbs of weight savings, gotta shave all ya can.
Yeah its a handy spot to put a foot also.
I just tossed the one out of my 86 the other day, and aimed the line downward. If I were to try and fix it proper like, and had a few dollars to blow, I would probably run the vent tube over to a small K&N style vent filter, and mount it hanging downward on the inside of the fender support bracing, to shield it from water, and tuck it away.
The being said, Im having vent issues at the moment, but I'm sure it existed before I removed the canister, as I haven't plugged anything. Its not really a problem that's concerning me though, the fuel cap may not be vented.
In all actuality, now that I'm thinking about it, I wonder why a person couldn't just plug the line up front, and run a vented cap.
Dru is offline   Reply With Quote
Old 11-24-2010, 02:41 PM   #13
kikkegek
kikkegek's Avatar
got another question that came up today.
What does this thing do in the red circle?
It is not connected to anything at the moment...
Old 11-24-2010, 06:29 PM   #14
Dru
Pretty much an old hot rodder myself, so I dont know all of the fancy names for junk I usually omit, but I'm pretty sure that's your EGR valve, you can take a quarter inch piece of flat steel, and using the removed component as a temple, and fabricate your own block off plate for it.
I'm pretty sure they sell them aftermarket, but I'm just used to making anything I can, I guess.
Old 11-24-2010, 06:40 PM   #15
benoit454
Chris
benoit454's Avatar
yep that's egr, or exhaust gas recirculation valve. it dumps exhaust into the intake to reburn it and lower nox emissions, it can be removed and blocked off if you don't have emissions to pass. You definately can buy them from summit, jegs, advance, autozone etc. or make one, the block off plate that is.
As for plugging the vent line off and running a vented cap, nothing I heard you can do that and it work fine. Our 84 with the charcoal can had vent issues, the cap coming off would let air hiss out of the tank or cause the metal fap inside to flap back and forth, kinda like the truck was farting LOL. After removing the can and letting the line vent under the inner fender, still does it, but not as bad. We took it off, did the same on my 85 mcss since it was missing and my 88 now has it gone to. I do smell gas fumes from my 88 but the rest I don't.
Chris
GIT R DONE!!!!!!
Old 11-24-2010, 07:31 PM   #16
Dru
kikkegek, if ya keep removing stuff, you might actually save a little mpg from not having to carry around that extra weight.
benoit454, that exactly what mine is doing. If that vent line that ran to the canister was working as I thought it was supposed to, it shouldn't build up any pressure at all, kind of curious to whats going on there myself. I'd almost swear I get worse mpg if I let it build up for awhile, but that could all be in my head.
Picked up another fuel cap that I had laying around here, its the plastic type like is in my truck, I thought I was going to switch it out to test, but the vent in this cap doesn't work well either, and its supposed to be a vented cap, takes a fair amount of pressure to get any air through it.
Sorry to kind of wander off topic.
Old 11-24-2010, 07:46 PM   #17
benoit454
Chris
benoit454's Avatar
same here, I've checked the line for bends and kinks and found nothing, I even tried to blow thru it from up front with the air compressor and it does barely, it's like it's an in tanke problem for us.
The egr should have ported vac. I'd guess and it can be checked with a hand vac. pump to see if it's working, if not it can cause rough idle or stalling, and not sure what it does if it's stuck shut I think maybe see a tad hotter temp and of course more nox, and maybe a tad bit of mpg difference(worse not sure). if it's stuck open it's a big vac. leak or maybe stuck shut too I forget.
Chris
GIT R DONE!!!!!!
Old 11-24-2010, 09:56 PM   #18
lilpoindexter
lilpoindexter's Avatar
easy picking!
If you are running LPG only, you are already super clean emissions-wise, so don't feel guilty about pitching it
lilpoindexter is offline   Reply With Quote
Old 11-25-2010, 07:23 AM   #19
kikkegek
kikkegek's Avatar
thanks guys for all the answers.
I have read somewhere that the EGR valve helps in warming up the engine more quickly en in fuel efficiency? is this true?
How does this EGR thing in the circle work? does it open up something that is underneath it?
How should this whole thing be connected? should it in any way be connected to the valve in my exhaust?
this one:
In my other topic it is discussed in page 3 link to page 3
Old 11-25-2010, 12:39 PM   #20
piecesparts
Parts and more parts
piecesparts's Avatar
I set my vent line up with a fuel filter on the end of it and then positioned it up under the front fender. It vents and the filter keeps water and dirt out of the tanks. I removed mine years ago and the only thing that I have noted, is that sometimes there might be a little of a bit of pressure on the tank when I uncap it to fill it.
Frank
