11-24-2010, 06:13 PM | #1 |
TH400 driveshaft not going all the way in
My friend took out his transmission (TH400) to install a new fluid pump, and then re-attached it to his truck. He is having trouble inserting the drive-shaft all the way. He says it won't insert fully, and has tried lubing it and twisting it, but it won't go all the way in.
Have any ideas? |
11-24-2010, 07:17 PM | #2 |
Re: TH400 driveshaft not going all the way in
well its not supposed to be bottomed out in the trans.
11-24-2010, 08:50 PM | #3 | |
http://community.webshots.com/user/hotrodhorn |
11-24-2010, 09:29 PM | #4 |
wow, you are so halarious. You should be a comedian on AGT.
Stock driveshaft to my understanding. See this thread for the context: http://67-72chevytrucks.com/vboard/s...86#post4300086 |
11-24-2010, 09:46 PM | #5 |
Look for twisted splines, both on the shaft and inside the yoke. It's not common, but it can happen. You may have to pull the tail housing to fully inspect the shaft.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. Last edited by raycow; 11-24-2010 at 09:51 PM. |
11-24-2010, 10:28 PM | #6 |
Does the end of the output shaft have a threaded hole? If it does the splines on the output shaft are NOT machined all the way because it came with a bolt on yoke.
If this is your problem changing the output shaft with a fully splined one whould be the correct fix. |
11-25-2010, 04:13 AM | #7 | |
Tags |
driveshaft, pump, th400 |
