Old 11-28-2010, 03:01 PM   #1
shawnkrug
Having issue with lug nuts comming loose ? / now I need a new rim..
Front left, drivers side, keeps comming loose. I just put new studs and nuts on this side. torqued to 125. I think the holes are too large on the rims now for sure.. Any how I require a new rim 15 inch rally rim of 6 lug, if you have one and you are in the lower bc ( chilliwack ) area please assist, much appreciated.. Thanks
1972 , 4x4, 383 BOAT puller!
shawnkrug is offline   Reply With Quote
Old 11-28-2010, 03:19 PM   #2
geezer#99
geezer#99's Avatar
Re: Having issue with lug nuts comming loose ? / now I need a new rim..
I'll send you a pm with some info of a possible wheel source.
Old 11-28-2010, 03:21 PM   #3
71swb4x4
71swb4x4's Avatar
You need to post this in the parts board. Here is the 67-72 parts board: http://67-72chevytrucks.com/vboard/forumdisplay.php?f=8
The 73-87 parts board may be more appropraite since it's a 73-87 rally wheel. http://67-72chevytrucks.com/vboard/forumdisplay.php?f=5
Did you check car-part.com like I suggested in the first thread you had started? It lists Canada too. It's a great site.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 11-28-2010, 10:39 PM   #4
71swb4x4
71swb4x4's Avatar
Car-part.com says that A Combined Used Truck Parts 1-604-853-2184 has a couple in Abbotsford and Wasney Automotive LTD. 604-526-4266 in Burnaby has a few. There are MANY others too, those are the first two on the list.
Old 11-28-2010, 10:46 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it's most likely the wheel causing the issue.
