Old 11-28-2010, 05:39 PM   #1
ksbeatty
ksbeatty's Avatar
Windshield wiper wiring
I have a 70 chevy wiring issue. The wiper motor does not match the diagrams or pistures I have seen. I have a single black wire, then a light blue and dk blue wire that all go back to the switch. The issue is the yellow wires go to the dk blue and light blue and not the black. Of course, I have a yellow wire that goes to the fuse block. When I turn on the truck the wipers move a little but they do not work. If I move the wipers to the windshield and turn the motor on the wipers go to the rest position and then still do not work. I try to test by grounding each of the blue and the light blue and still nothing happens.
Is it the motor? Or is it the wiring?
I have mixed and matched some parts from the 70 Chevy and a 69 GMC butI thought they were all supposed to be the same. The wiring harness and the motor I know go together.
Thanks for the help.
1969 GMC 3/4 Ton 4x4
2" Lift, A/C, PS, PB
383 Stroker, 700R4, 205, 4.10 GM
Medium Bronze (Copper Poly)
no new nick name yet. She is to pretty to be the Beater.
http://67-72chevytrucks.com/vboard/s...d.php?t=241855
ksbeatty is offline   Reply With Quote
Old 11-28-2010, 07:38 PM   #2
JimKshortstep4x4
Re: Windshield wiper wiring
From your description, it sounds like the motor is bad. If you have power on the yellow wire and you ground the two speed connections then the motor should run. (This assumes that the motor ground ids ok).
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-28-2010, 10:40 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Might be something you can use here...
http://67-72chevytrucks.com/vboard/s...d.php?t=413551
LockDoc
Leon
