Old 11-29-2010, 08:17 PM   #1
cppursell
cppursell's Avatar
Put TH400 back in, won't shift
Well, I've been creating several threads with different issues of my friends' '63 C10. It started with putting a new engine in (which is running great now, woohoo). When attaching the transmission he broke the pump, which he replaced and now the car moves, but: It won't shift out of first gear! My friend has an idea that the solenoid on the transmission for the electric kick-down might be causing it, but I haven't a clue. Can you pros help?
Thanks!
cppursell is offline   Reply With Quote
Old 11-29-2010, 08:38 PM   #2
69 longhorn
Re: Put TH400 back in, won't shift
do you have the vacumn line hooked up to the modulator?
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 11-29-2010, 08:54 PM   #3
cppursell
cppursell's Avatar
Yessir, he reports his vaccum is plugged in correctly to the intake manifold, and there is a good suction. I suspected this myself as possibly being a problem. Maybe his modulator is bad?
Old 11-30-2010, 05:10 PM   #4
68 TT
Still plays with trucks
68 TT's Avatar
The kick down circuit probably wouldn't keep it from shifting. I would bet you are correct and the vacuum modulator is bad or damaged and leaking vacuum. Without it functioning the trans will not shift out of first gear.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-01-2010, 04:10 AM   #5
cppursell
cppursell's Avatar
Okay I will let him know. Replacing the modulator is cheap anyway and wouldn't hurt.
Old 12-01-2010, 02:50 PM   #6
raycow
If the modulator doesn't do it, you could look at the governor next. The symptoms are about right, but I have no clue how there could be any connection with a damaged pump. A more likely possibility might be that a small piece of debris from the pump somehow got into the valve body.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
1st, c10, shift, th400, truck
