Old 11-29-2010, 09:35 PM   #26
masterlock
masterlock's Avatar
Re: Cab differences???
Ok as promised I have pictures. After long inspection all I have found different in the cab is there is no hole for wiper controls (no big deal), the floor hump is different and the dash has a few extra holes but the 77 dashpad will fit so will the cluster. The wiper set up is different but not in any crazy way. Here are the pictures.
masterlock is offline   Reply With Quote
Old 11-30-2010, 03:20 PM   #27
masterlock
masterlock's Avatar
No further discussion?
Old 11-30-2010, 03:59 PM   #28
big_b
Well, ok,,, i can see in your picture that the ear for the top front fender mount is not on your newer cab, neither is the rear hood support. compare your old cab cowl with the new one. it only matters if you are going to use the older front fenders/hood with the new cab
big_b is offline   Reply With Quote
Old 11-30-2010, 04:12 PM   #29
babyJay
Arrived on a Pale Horse
babyJay's Avatar
And that is definitely not an 88 cab.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 11-30-2010, 06:07 PM   #30
GM72K10
Next!
GM72K10's Avatar
Come on, of course it could be an 88 cab, could be a 88 R30 or V30 cab. Its not the 88 C or K cab though.
And by the way, that cab is in great shape now matter what it is!
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 11-30-2010, 06:29 PM   #31
motornut
78K & 79C Jimmys
motornut's Avatar
88 going by the number on the jam?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 11-30-2010, 06:39 PM   #32
babyJay
babyJay's Avatar
Yep! And it is a nice cab! May have been a 1 ton service vehicle, judging by the yellow paint.
Jason
89 R3500 CC SRW
Old 11-30-2010, 07:17 PM   #33
bigblock73
yeller
bigblock73's Avatar
There were NO square body LD regular cabs made after 87, they were all crew cabs. C/K is for 73-86, R/V 87-91...when referring to square bodies.
bigblock73 is offline   Reply With Quote
Old 11-30-2010, 09:08 PM   #34
Da88burban
GM's 4 Life
Da88burban's Avatar
Well they did make square body reg cabs after 87 in Mexico tho. But I would not think that is one.
Jack
'54 Chevy 3100 "Just a Mess"
'74 Chevy Super 10 468BB "One Fast Rust Bucket"
'86 Pontiac Fiero GT
'88 Chevy burb "Tha Big Turd"
'93 GMC Safari "Bone Crusher"
.................____________
.............../______l___|___\____
;,;,;,;,;,;,;|__(O)_| __l___l__(O) |
Da88burban is offline   Reply With Quote
Old 11-30-2010, 09:47 PM   #35
masterlock
masterlock's Avatar
I do live in San Diego so maybe it is a Mexican cab. I understand that there may need to be some adjustments to fit the hood and fenders but I think it is do-able.
Old 11-30-2010, 10:00 PM   #36
babyJay
babyJay's Avatar
I like the custom cab cart you made up.
Jason
89 R3500 CC SRW
Old 11-30-2010, 10:13 PM   #37
masterlock
masterlock's Avatar
you know Im just gonna get the VIN off the cab tomorrow and lay this year guessing to rest. Im a genius!
Old 12-01-2010, 05:53 PM   #38
russgt
russgt's Avatar
Either way, it looks like it is in awesome shape. use it and modify it to your needs.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 12-01-2010, 06:34 PM   #39
GM72K10
Next!
GM72K10's Avatar
Wrong, 88 you could get a K30 dually pickup square body style, single cab square body Cab and chassis were available in 88 and 89. I had one.
Heres an 88 single cab V30 that was for sale on this website:
http://67-72chevytrucks.com/vboard/c...t=3158&cat=all
86 K30 CUCV M1028A1
Old 12-01-2010, 06:47 PM   #40
benoit454
Chris
benoit454's Avatar
I want to see this said ear for the older style front fender mounting anyone have a pic?
My question would be what front end are you going to put on this cab the older pre81 front? If so then as mentioned the linkage for the wipers is shorter post and the holes that mount them don't line up, hole in the dash for the switch, floor mount dimmer switch? our 76 had that and 84 is on the column switch.
That's all that I know of other then just the front clip which I thought worked fine on the newer cabs, I thought the biggest thing was if you had an old cab and wanted a newer clip you had to cut holes and such. I thought an old clip on a new cab was a bolt on deal. Minus of course the wiper linkage.
You guys have me curious now though on the said old cab mount ear for front fenders I need some pics plz!!!!
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 12-01-2010, 09:50 PM   #41
bigblock73
yeller
bigblock73's Avatar
I stand corrected, thought the single cab dooleys went to the new bodystyle in 88.
Old 12-02-2010, 06:38 PM   #42
masterlock
masterlock's Avatar
Chris here are some pics of the 77 cab it all looks the same to me
Old 12-02-2010, 07:03 PM   #43
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Regular cab R/V style was available up to 1989 in 3/4 and 1 Ton versions
The C/K style 3/4T and 1T took over in 1990.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-02-2010, 09:08 PM   #44
GM72K10
Next!
GM72K10's Avatar
Once and for all:
Square bodies were available as 3/4 and 1 ton Crew Cabs until 1991 as R or V series. The last single cab available square body PICKUP was in 1988, ONLY as a V30 pickup, particularly V30903 dually only. Square body SINGLE Cab and Chassis were available in 88 and 89 as R or V 31003 31043 ONLY (i.e. 1 tons) no 3/4 tons. Square body Jimmys and Blazers and Suburbans were available until 1991.
86 K30 CUCV M1028A1
Old 12-02-2010, 09:12 PM   #45
bigblock73
yeller
bigblock73's Avatar
Once and for all:
Good info, thanks for sharing. Can I lift this scan for www.73-87.com?
EDIT: I see you came back and added Suburban to the list I commented, but them had to edit mine after you did yours...lol
Old 12-02-2010, 09:18 PM   #46
GM72K10
Next!
GM72K10's Avatar
Sure, couldn't figure out how to post it horizontally though.
86 K30 CUCV M1028A1
Old 12-03-2010, 12:37 AM   #47
motornut
78K & 79C Jimmys
motornut's Avatar
done
John
Old 12-03-2010, 12:45 AM   #48
benoit454
Chris
benoit454's Avatar
thanks for the pics looks the same to me too, maybe it's the flat where the cowl meets the sides, the ridge that runs downward on an angle on the front of the firewall, yours sticks out more in the front then in the back and has a square hole in it, I think the newer style sticks out the same front to back and maybe doesn't have that hole?
I think I found it...
http://67-72chevytrucks.com/vboard/s...&postcount=287
2nd and forth pic shows a flat area like rusty looking that has a hole in it for like where a bolt of body clip for a bolt goes. I don't think the 81-87's have that and that's the ear he was talking about above.
the 81-87's have a series of holes but they don't stick out as far as the others maybe?
http://67-72chevytrucks.com/vboard/s...1&postcount=53
http://67-72chevytrucks.com/vboard/s...1&postcount=88
Chris
GIT R DONE!!!!!!
