Test a relay fuse????
I have a 2001 sub and the headlight just quit this morn. Can you test the HDLP relay fuse? All else is working fine. The only fuse I find for headlamps is the relay and just to the right a 15a for r and l hdlp. All of these under the hood in the box. Any help? Gary
One day...
![]() Join Date: Apr 2008
Re: Test a relay fuse????
I know is sounds like a stupid question but did you check the bulb also?
![]() Join Date: Sep 2005
pull the fuse and see if it is blown. do the high beams work or did both good out? have you check teh bulbs? i always recommend replacing headlights in pairs because they both run the same amount of time and tend to go out around the same time
