climate control system question
does anyone make a replacement vacuum line set for the a/c controls that plugs into the vacuum valve control
Re: climate control system question
anyone please? cause im up crap creek without a paddle without 1
When I was rebuilding my vacuum system I could not find those hoses. Mine have a special connecting end molded into the hose (the way it looks, anyway.) You can search for small I.D. hose which should work on the net - I don't remember where I found it. Use your calipers to get an accurate dimension. I ended up reusing my original ones, since they held up pretty well even in AZ heat because they were protected under the dash. Good luck.
