Old 12-01-2010, 03:25 PM   #1
smokinstang70
smokinstang70's Avatar
Hidden Hitch w/ Boyd Rear tank
Does anyone have a picture or info on installing a hidden hitch with a Dave Boyd rear mounted fuel tank? I bought a Boyd tank and am ready to install but also want to install a hidden hitch. Looking for ideas.
Any pictures of any rear mounted tank and hidden hitch?
smokinstang70 is offline   Reply With Quote
Old 12-01-2010, 03:42 PM   #2
flashed
Re: Hidden Hitch w/ Boyd Rear tank
Where are you buying the hidden hitch from ? I cant find one on the east side of the country ,trying to save on shipping . I cant answer your question as my tank is still in the cab .
flashed is offline   Reply With Quote
Old 12-01-2010, 04:36 PM   #3
smokinstang70
Carolina Classics $169.00
http://www.carolinaclassictrucks.com/ECE-06-6772bh.html
Old 12-01-2010, 05:18 PM   #4
Clyde65
Clyde65's Avatar
I saw in one of their GB's someone asked that and Dave said IDK, so here is what I say. Since the tank bolts to the bottom of the frame and doesnt have mounting holes(I think), I would mount the tank and then put the hitch up there and drill the holes, you would probably need to get longer bolts and it might be a challenge to tighten the bolts once it is all on but I bet it can be done no problem.
I also heard that you can put the tank on the top of the bottom part of the frame rail but the vent might interfere with the bed.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-01-2010, 05:37 PM   #5
smokinstang70
I agree... however my concern is sandwiching the aluminum flange for the tank in between the steel frame and the steel hitch. I just want to make sure the soft aluminum doesn't deform over time... especially with a load being applied to the hitch.
Old 12-01-2010, 05:40 PM   #6
Clyde65
Clyde65's Avatar
I think the flanges for the tank are made out of some pretty thick stuff, I would call Dave and ask him his .02 on that and worse case I would see about putting the tank on the inside of the rail.
Clyde65
Rebuild of Clyde
support our troops!
