Initial Valve Adjustment
I'm doing final assembly on a 350. What is the proper way to set the valves for initial break-in? I'm using an "RV" style hydraulic cam, barely larger than stock, and Vortec heads.
Andrew68c10 go to the cranecams link go down to the section for
Using Adjustable Rocker Arms to set Hydraulic Lifter Preload The other link has so good info if you are concerned with geometery or clearances. I usually like to use a half turn on a new engine I'd rather be a little loose than to tight. Good Luck....Stroker http://www.hi-flow.com/HPValvetrainInstal..htm http://www.cranecams.com/master/adjustvt.htm
72 SWB parts and pieces Oklahoma |
are you using self aligning rockers..or guide plates? Its easier to do the adjustments if the intake manifold is off
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
