Parklights
Hi All,
Can someone let me know if the parking lights should be ON when the headlights are ON ? I cleaned up the a bunch of wiring by the front driver side headlamp as after I removed the electrical tape I found many twisted connections and unconnected wires. After a bit of soldering and cleaning up I found that when I put on my headlights only the passenger side front parking light is on. I bet you have all seen messes like this on your trucks... Thanks Jay
![]() ![]() ----------------------------------- { 1972 Chevrolet C-10 Fleetside, 350 V8, 5.7L. } ----------------------------------- |
Re: Parklights
I know on my 72 GMC when the headlight are on there is no front clearance lights on.
1991 GMC K2500 4X4 350/auto 1991 Chevy S10 ext cab. 1990 Chevy S10 1993 Chevy S10 Blazer 4dr 4.3 Vortex/Auto |
Cruzin
Re: Parklights
on the chevrolets i know that 67 and older doesn't come on with the headlights, 68 and later goverment reg. made is were the park lights headlights are on together. That being said is it connected good at the radiator support also i would check to see if it is grounding good
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
Cops, ha, catch me if you can!
Re: Parklights
I have a 72 C-10 and all the parking/marker lights are on with the headlights. The front markers on the fender even flash when the turn signal is on.
72 C-10 Stepper 350/TH350 3.73 in the back Edelbrock intake and Carb Hooker Comp Headers 275/60R15 on Rallies ![]() ![]() |
needs more $$$
Re: Parklights
There's probably a bunch of stuff to check, but I would first look to the connection at the radiator support there's power to it & the bulb itself. If there's no power to the light, it would need to be chased back to see if it's connected since I take it the passenger is working correctly. If there is power, check the grounds or even power at the bulb housing.
1970 2wd Blazer |
