Old 12-03-2010, 04:19 AM   #1
kikkegek
kikkegek's Avatar
grease electric window mechanism without removing doorpanel
temperatures are down to freesing at the moment en the electric windows of our burb are giving us a hard time. very slow and sometimes not fully opening or closing.
I opened up one doorpanel recently and saw that the mechanism is as dry as a dessert-rats-ass...
Is there a way of greasing this mechanism without having to open the doorpanel, because that is way too cold right now and I have no place to do that inside.
hope you guys can help me!
kikkegek is offline   Reply With Quote
Old 12-03-2010, 06:51 AM   #2
tucsonjwt
Re: grease electric window mechanism without removing doorpanel
I don't know of any way. Removing the door panel doesn't take very long, as you know, but I understand the problem with cold weather. However, I would not necessarily think that grease alone will solve your problem - could be cold weather affecting the performance of your motor(s).
tucsonjwt is offline   Reply With Quote
Old 12-03-2010, 07:03 AM   #3
kikkegek
kikkegek's Avatar
I was afraid I'd get reactions like this! man, I dont feel like taking off the doorpanel, but think its probably the only way.
probably motorproblems too, but I wanna make sure its greased properly to take that out of the way....
Old 12-03-2010, 07:44 AM   #4
LONGHAIR
You could always get to it from the outside, an air-chisel will peel that sheetmetal right out of the way.... Ha
No, really the only way is to remove the door panel. Just be sure to use something that can deal with the cold. A synthetic lube that will not turn sticky and stiff when it is freezing would be best. There is no point in going from "dry" to "glued"
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 12-03-2010, 07:54 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
had to replace the fuel tank,and it was real cold
threw big tarp,covered ground to ground on sides
hung over the gate ,put heater inside truck pointing at me
and a rope around the belly,boards up the sides
also make sure the window and tracks are lined up straight
well greasin things make sure to do the hinge for the door
with out they sieze/stiffen up,seen them bend
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 12-03-2010, 01:08 PM   #6
terryj
If you can get your hands on some grease rated for artic conditions that would be the was to go. When I lived in Fairbanks, AK that was the type of grease I used, it doesn't harden up under extream cold conditions. Used it on the windows and everywhere else you need to grease, mostly the wheel bearings.
terryj is offline   Reply With Quote
Old 12-03-2010, 01:17 PM   #7
kikkegek
kikkegek's Avatar
do you have a link to what you used to use?
Old 12-03-2010, 03:43 PM   #8
terryj
The grease is made by TS Moly called TS-67, it's a good grade to arctic grease.
I don't have a link for them but it shouldn't to hard to find.
