Old 12-03-2010, 06:40 PM   #1
mikewarme
tach guage
So i can't use a factory tach guage with HEI, right? Is there a aftermarket guage that fits the cluster that could be used? Or is it out of the question?
mikewarme is offline   Reply With Quote
Old 12-03-2010, 06:58 PM   #2
Dark Knight
Dark Knight's Avatar
Re: tach guage
I'm pretty sure that you can use the stock tach on an HEI distributor. Just hook it up to the tach plug-in. There's a thread on here somewhere about it.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 12-03-2010, 07:20 PM   #3
71swb4x4
71swb4x4's Avatar
Re: tach guage
I have used them with HEI. No changes at all, just plugged it in.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-03-2010, 07:48 PM   #4
novafrog
novafrog's Avatar
Re: tach guage
x2,check your pm's
72,2wd short bed cheyenne,350,350trans,air,tilt,tach,posi 373 gears
70 nova 5.3,350 trans
80 z28 350,350,trans,bought new
03 cat.
06 gmc swb ext cab
novafrog is offline   Reply With Quote
Old 12-04-2010, 03:04 PM   #5
raycow
Re: tach guage
This appears to be a sometimes issue, and may depend on the type of HEI. However, the tachs that don't work properly can be modified, so you don't need to throw away an otherwise good tach.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 04-21-2011, 05:00 PM   #6
mikewarme
Re: tach guage
Any other opinions? I wanna buy a new cluster with tach but am afraid I might damage it with hei
Old 04-21-2011, 05:57 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Re: tach guage
you will not damage it with hei. i have run two trucks with factory tachs and hei. no problems.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-21-2011, 07:34 PM   #8
brad_man_72
the boat guy
brad_man_72's Avatar
Re: tach guage
hei/tach no prob here either. Now I'm running factor tach w a ls computer
brad_man_72 is offline   Reply With Quote
Old 04-21-2011, 08:30 PM   #9
ricks71pu
ricks71pu's Avatar
Re: tach guage
same here, transplated 1975 454 with HEI in my GMC 3500 (longhorn), factory tach, no problems.
In the words of my favorite poet, singer/songwriter (Paul Thorn):"What ever you believe, you might be wrong"
ricks71pu is offline   Reply With Quote
Old 04-21-2011, 08:34 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: tach guage
every once in a while someone hooks up a 40 year old tach to HEI and it doesn't work. However, by design, it'll work.
Old 03-28-2012, 10:11 AM   #11
mikewarme
Re: tach guage
Ok guys its been almost a year since we touched on this subject here last. I installed a factory tach last summer. Only driven 300 miles. Tach worked great. Took cluster out to change temp guage and when I was done the tach didn't work. Was stuck at 2000 rpm. So I bought a new one from classic industries and replaced it. Realizing when I had replaced the temp guage I had bent the backing just a touch on the tqach and that was the problem! I installed the new tach anyways. Took the truck yesterday to a guy who tuned the truck real nice. Took my streetfire msd distributor and put it on a machine to set the advance and just really tuned it nice. Drove it 4 miles from his place with the tach working ok, and suddenly I smelled burning and here comes smoke from the cluster. Tach goes dead (along with my heart). Than a few min later it started working again. When at idle the needle jumps. So im sure something in the tach smoked. Could this guy have hooked his light wrong to the truck and smoked it for me? Other ideas?
Old 03-28-2012, 03:52 PM   #12
Spoof
Spoof's Avatar
Re: tach guage
Reproduction gauges with tach, plugged into ramjet HEI has not worked.
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 03-28-2012, 04:43 PM   #13
502ms
502ms's Avatar
Re: tach guage
I'm using AutoMeter SportComp tach with HEI, no problems
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 04-17-2012, 12:06 PM   #14
mikewarme
Re: tach guage
Mounted in factory cluster??
