Old 12-04-2010, 08:44 PM   #176
menace121978
menace121978's Avatar
Re: My '87 SWB Project w/pics!!
hey Trev, where is the bolt broke at? on the drivers side very front?
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 12-04-2010, 11:31 PM   #177
twoodson
I be damn, Dennis I swear either you have a camera in my garage or I have been watching you with the black/silver theme or great minds just think a like. It was the driver side 1st one.
twoodson is offline   Reply With Quote
Old 12-05-2010, 08:14 AM   #178
menace121978
mine is like that too and so is the goats ls2. i'm thinking they are supposed to be like that
"Dennis the Menace"
Old 12-05-2010, 08:38 AM   #179
menace121978
damn... just got your message. sorry i missed your call last night. i was in bed at 6! works just an @ss kicker this time of year. give me a call today buddy
"Dennis the Menace"
Old 12-06-2010, 11:23 AM   #180
Jonboy
Slots go on anything!
It's looking good. now use more of those days off and lets see this sucker move!!!!
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 12-06-2010, 12:53 PM   #181
Puglia10
Nice work! I need to clean my motor soon....I also have TWO exhaust bolts broken off seems very common for these motors.
1979 c30 3+3 dually
1946 GMC
Puglia10 is offline   Reply With Quote
Old 12-06-2010, 01:35 PM   #182
cable666guy
cable666guy's Avatar
Wow!! Talk about snowballs!! Keep at it, man...It's coming along really well!!
cable666guy is offline   Reply With Quote
Old 12-06-2010, 10:14 PM   #183
twoodson
Update, I got the engine painted and it turned out pretty good, sorry for the crappy pic. However I may have to replace the driver side factory cylinder head due to the front exhaust manifold bolt had broken off and we were unsuccessful in extracting it. Not sure if it would cause an exhaust leak or not. My buddy and I basically filled and grinded it down smooth. I am prepared to purchase a factory head however we are planning on trying to heli coil it. Be aware that the exhaust manifolds have been prone to breaking either flush with the cylinder head or it will leave more bolt like a stud. I guess things were running to smooth.
Old 12-07-2010, 05:46 PM   #184
JJAB
Trevino, whats up? This is Tommy out of Waco. I bought the two saddle tanks from you about 5 months ago. Anyways, your truck looks good and you are making excellent progress. Looks like you will be the envy of town once you are finished. I remember, the last time we talked, you were planning on moving forward with your TBI motor. I see plans have changed. My two cents... Excellent choice on the LS1. I have put one in a four door swb squarebody and you cant beat them.
JJAB is offline   Reply With Quote
Old 12-07-2010, 10:38 PM   #185
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Can't tell for sure from this last pic you posted but did you paint the aluminum heads or just polish them up??
It's looking good!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 12-08-2010, 01:15 PM   #186
americanmuscle
if you cant get a bolt in there it will not work and will leak like crazy. go ahead and find another one and get a new gasket kit.
Project "Abby"
84 swb 6.0 swap and rebuild.
http://67-72chevytrucks.com/vboard/s...d.php?t=395121
americanmuscle is offline   Reply With Quote
Old 12-08-2010, 05:47 PM   #187
twoodson
Puglia10 - yeah I noticed I had one broke on my suburban, the bad part is that on my motor is that i had none sticking out the head or I would have used vise grips, mine was a little beneath the bolt hole and i used the incorrect size extractor and some of broke off, sucks but what the hell.
Cable666guy - yeah there is a lot of peer pressure on this site, thanks for the compliments
JJAB - thanks for the compliments boss
Gordonr1973 - Thanks for compliments chief; no just did scotch brite on the front of them, trust me they coul look better.
americanmuscle - Yeah I know, we are going to attempt to weld a stud there to see if it will hold up to the strength we need if not I got a contact who has some GM overstock brand new 243 casting heads which from what i have researched are the same as 799 casting and they are the ls6 heads or something like that. They are an upgrade to what I have so it is what it is. This puts me back 30 days because the money i had saved were for the dirty dingo adapter mounts and schoenfeld ls truck headers. living and learning the hard way.
Old 12-08-2010, 09:14 PM   #188
menace121978
so the ls6 heads will work with the stock intake and fuel rail from your motor?
"Dennis the Menace"
Old 12-09-2010, 10:06 AM   #189
twoodson
Dennis - from what the gentleman told me, yes they will work, that was the first thing I asked I may have to do some more research just to make sure.
Old 12-09-2010, 10:10 AM   #190
Jonboy
Pimptastic!
Old 12-09-2010, 04:00 PM   #191
americanmuscle
yes they will. all cathedral port intakes work with all cathedral port heads. if you can spring for an ls6 intake to go with the heads its worth a few ponies up top, the stock truck intake is good for low end though.
check ebay for a set of heads. they will be listed as ls6 or ls2 heads and you can find rebuilt heads for pretty good prices on there. any 243 or 799 casting will be just fine.
Project "Abby"
Old 12-10-2010, 09:15 AM   #192
twoodson
americanmuscle - thanks for that input and confirmation.
Old 12-10-2010, 10:40 PM   #193
justpball
justpball's Avatar
sweet build bud!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 12-11-2010, 01:05 AM   #194
twoodson
justpball- thanks boss, hopefully I cn be close to your level one of these days.lol
Update - I found a better deal on some stock truck 5.3 heads thru a buddy and I should have them next week which will save me quite a bit. I will have to buy a Fel Pro gasket kit. Hopefully I can order up the Dirty Dingo adapter plates on Monday. The Schoenfeld headers will have to wait till after Christmas. Anyways today I picked up my alternator case from my powder coater and had it put back together. I also put the power steering pump back in the resevoir. So here is a pic, not much but enjoy. Me and a buddy also removed the heads today, just waiting to get the other ones next week and get back on track. One more thing I just painted the water pump (silver) tonight, I will paint the pulley (gloss black) tomorrow and post a pic. The p/s pump looks dull in the pic but it's the lighting they both look the same in person. the p/s pulley is powder coated gloss black as well.
Old 12-11-2010, 11:35 PM   #195
twoodson
Update - I finished painting the water pump and pulley and it came out pretty good, I got a little off on the taping but I think it looks okay. The crank pulley is also gloss black. I will probably do the idler & tensioner pulleys tomorrow. Been ripping and running all day long. Not much but enjoy. The plan is to run the kwikperf a/c relocation kit. I am about to browse summitracing for different style of sanden compressors in polished.
Old 12-11-2010, 11:37 PM   #196
menace121978
looking great bro! im loving all the touches of silver and black
"Dennis the Menace"
Old 12-12-2010, 08:38 PM   #197
twoodson
Thanks Dennis, you know great minds think alike.. lol
Old 12-13-2010, 09:20 AM   #198
JohnC
JohnC's Avatar
Looks good man. Keep at it!
JohnC is offline   Reply With Quote
Old 12-13-2010, 09:28 AM   #199
twoodson
JohnC - Thanks bro, I am trying to!!
Old 12-16-2010, 11:27 PM   #200
twoodson
Good evening gents; not much to report, I should have my heads next week and probably will put them on Christmas Eve. However I did paint the tranny and the tensioner pulley. I probably went a little overboard and should have painted the entire tranny silver but I did the tailshaft in gloss black. If I had a money tree I probably wouldn't have so much time on my hands.lol Don't laugh!! Enjoy!!
