12-05-2010, 08:59 PM | #1 |
It'll Buff Out!
Can I eliminate The Cardboard in front of the tank?
Pulled the Tank on my 72 and the cardboard is trashed. Can I eliminate it? I was thinking of spraying the tank with a sound deadener or maybe building something similar with thin abs and covering it. I'm going to line the cab behind it anyway with dyno mat. Not sure if this is one of those items that serves some secret purpose or not.
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
12-05-2010, 09:03 PM | #2 |
Re: Can I eliminate The Cardboard in front of the tank?
I think it was purely cosmetic. It's hard to find an old truck with one nowadays because they fall apart so easily. I've taken them out of 2 trucks that I have owned without any ill side effects.
-Scott- |
12-05-2010, 09:07 PM | #3 |
BlahBlahBlah
My 71 had ugly green carpet on the floors and the tank. I ripped it all out when I installed factory style rubber mat and heat/sound deadener on my floors. Cardboard was probably cheap sound deadener or something to keep any raised edges on the tank from rubbing the back of the seat (guesses)
… … … … … … … … ... … … … … … … … … … … … Last edited by CG; 12-05-2010 at 09:07 PM. |
12-05-2010, 09:25 PM | #4 |
Active Member
I suspect it was GM's cheap way to cover the gas tank (cosmetics). I doubt it did anything for sound deadening in these old trucks. I took mine out of both of my trucks.
12-05-2010, 11:53 PM | #5 |
Big Red - Now its a SWB!
Mine has been gone longer than I can remember and it is just fine.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
12-06-2010, 09:35 AM | #6 |
took mine off as i thought it served no purpose..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
12-06-2010, 03:15 PM | #7 |
Active Member
I popped for the reproduction cardboard. Believe me, you don't want to go there. It's a b**** to get all the creases right and it still doesn't fit well.
72 Sierra Grande 2500 BB 72 Sierra 2500, 42K miles, factory buckets 72 Cheyenne 20 72 Chevy SWB, Factory BB, Leaf Spring |
12-06-2010, 03:57 PM | #8 |
It'll Buff Out!
Thanks Everyone, I just wasn't sure if it had some magical purpose. as stupid of a question as it was, it's one of those things someone might have had a purpose behind it. At least now my gremlins will have no place left to hide in the cab.
