Old 12-06-2010, 01:54 AM   #1
treetop_73
treetop_73's Avatar
Did I fry my truck?
I tried to jump start my truck like I've done every 3-4 weeks lately since it just sits. I hooked up the wires like I've always done, Good battery negative then positive, then to my truck, negative then positive. Never had an issue before.
This time I got a spark when I was about to attach to the positive of my truck. Thought nothing of it and got back into the good battery seat and reved the engine a little. I got out and was walking to the truck when I saw smoke coming from the battery, the wires, and near the fire wall of my truck. I turned off the car, ran, grabbed gloves and took the cables off the truck and the car. They kept melting for a while. I tried to turn the key in the truck and got nothing at all. No lights on the dash, nothing. Later I went back out and tried and the dash lit up like the battery was dead.
Was it the cables, did I fry my truck? Any help is appreciated.
Here are the cables now...
'85 GMC High Sierra 2500
treetop_73 is offline   Reply With Quote
Old 12-06-2010, 02:14 AM   #2
bikes&bowties
bikes&bowties's Avatar
Re: Did I fry my truck?
did you cross them?
bikes&bowties is offline   Reply With Quote
Old 12-06-2010, 02:17 AM   #3
treetop_73
treetop_73's Avatar
Thats what I thought but I checked when I pulled them off and I didn't.
Old 12-06-2010, 02:21 AM   #4
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Might have fired the starting circuit. Check all the wiring you can before you put another battery to it.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 12-06-2010, 04:46 AM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
You fried the fusable links. Wires light up like that when they are crossed or system has a reverse feed somewhere. Dead battery ground should be hooked up last!! Ground on dead battery should be avoided. You should hook it directly to a metal bracket or engine bracket. I like using the alternator bracket.
Oh, cheap jump wires light up like that too.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 12-06-2010, 10:35 AM   #6
78cheyenne292
always put positives on first then the negatives.. and like gchemist said the dead bat nagative last and go to a a bracket on the truck not the battery
78cheyenne292 is offline   Reply With Quote
Old 12-06-2010, 11:17 AM   #7
treetop_73
treetop_73's Avatar
Thanks. I guess I will dive into it to try to see what I damaged. I have always used the terminals and in the order I wrote and never had an issue. I learned in auto shop back in high school but it makes sense it was wrong, the teacher was a pot head and seemed high everyday.
Thanks for the info
Old 12-06-2010, 11:33 AM   #8
78 Chevyrado
Seems like to burn up those jumper cables, it might have been hooked up backwards or you had a major short in the truck. Any of the wires in the truck should have burned and melted in two before the jumper cables had a chance to burn like that.
Maybe the battery itself had a short in it? It happens from time to time.
The whole trucks not a loss, just what the surge damaged. there is some wiring in your immediate future so replace ANY wire that looks burnt or brittle. It would also be a good idea to peel back a bit of the insulator on nearby related wires and see if the conductor inside is discolored. If in doubt, replace it! Make sure you're new wires are the same size (conductor) or a bit larger if you like. never use undersized.
Why you are getting nothing is that the wire you burnt is the one coming from the starter + to the fuse block. without that, its like the battery is unplugged.
78 Chevyrado is offline   Reply With Quote
Old 12-06-2010, 11:35 AM   #9
RandyP
Getting Old; Going Broke
RandyP's Avatar
Exactly. Always do positive and then ground, and ground away from battery. I was always taught that to avoid the spark, which could ignite if the battery has a fume buildup around it. Of course with most sealed batteries these days, probably not as big of an issue. I'm guessing probably bad jumper cables were the root of the evil here.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 12-06-2010, 10:54 PM   #10
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Check the fusible links at the starter. They may not look "bad" because the wire insulation is softer to allow the wire to burn inside without causing a fire. Wiggle the wires and feel for a damaged wire inside.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 12-06-2010, 11:50 PM   #11
treetop_73
treetop_73's Avatar
I've used those cables multiple times before without issue. This is just strange as I know the cables weren't crossed, thats what I checked first. Guess my weekends will now be filled. And I still haven't tried to get it smogged again since I failed in June. I knew this year should have been a non-op.
Old 12-06-2010, 11:55 PM   #12
treetop_73
treetop_73's Avatar
What's a fusable link? Where are they, are they hard to change?
Old 12-07-2010, 02:26 AM   #13
gchemist
gchemist's Avatar
A fusible link is a special wire. The wire basically blows like a fuse when it subjected above it rated capacity. These trucks have several. Look at the red power wires from the battery, alternator and main link fuse. The main link fuse is on the firewall next to the brake booster. Some wires will have an enclosed fuse. They are cylinder in shape and in-line with the wire. Take your finger and squeeze the wire. You'll know it fried because it will be very soft. I'll snap a picture of links I added at my battery connections.
Old 12-07-2010, 02:59 AM   #14
Mike Bradbury
Mike Bradbury's Avatar
Your battery should last longer than three weeks before it dies. Maybe there is a short somewhere that was slowly draining the battery.
On the cables sounds like pos. might of slipped, or rotated on the battery post and contacted metal like the fender or a bracket, maybe even the other clamp. Batteries have 700 to 1000 or more cranking amps in them the only thing that will melt a cable like that is if they get crossed or shorted. There isn't a wire under the hood that can sustain that kind of amperage for very long, so I doubt it was a pre-existing condition. Might have been a crack in the insulation of the cables and +/- made contact.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 12-08-2010, 12:21 AM   #15
treetop_73
treetop_73's Avatar
I'll have to read this while looking under the hood. Thanks. Pics would be great if you have time.
Old 12-08-2010, 12:22 AM   #16
treetop_73
treetop_73's Avatar
Thats what I was thinking. Too bad it melted together so now I can't see if there was a crack.
Old 12-08-2010, 12:25 AM   #17
treetop_73
treetop_73's Avatar
I get power now. Its like the battery just doesn't have enough power. I turn to on and the dash lights up, the radio is on, I turn the key and get a click.
Old 12-08-2010, 01:15 AM   #18
thirdstreettito
Resident of Here
thirdstreettito's Avatar
I'm thinking fusible links as well. Also, positive hook up first, as they said. Also, before you buy new cables, dont. Build a set. Use thick welding cables. They will last longer than you will live.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-08-2010, 07:59 AM   #19
parrisc19844x4_468
parrisc19844x4_468's Avatar
I had this happen a few yours ago, I had a short in my starter.
2017 Silverado LTZ 6.2
1984 Scottsdale K10 - 468 700r 4x4 lwb
1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb
1968 GMC 20 305 V6 good ole wood hauler.
Good Fences make good neighbors
parrisc19844x4_468 is offline   Reply With Quote
Old 12-08-2010, 11:34 AM   #20
Meatman
Meatman's Avatar
I would say you either hooked em up backward by accident like was said before or if you battery is really dead you can melt a cheap small gauge set of jumper cables pretty easy.
What ever happened it does sound like you fried some fuse-able links. You can burn up 1 or 2 of those and still have accessory power but truck wont crank. Best way to check them is to see if they are soft in the middle or grab the wires that come out of both sides and gently pull. If they pull apart easily then they are fried. You probably burnt through a couple of them.
Daily-94 K2500 350 5spd extended cab longbox
Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack.
Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881
My 01 TA and 88 Formula hide in the garage. :-)
Meatman is offline   Reply With Quote
Old 12-08-2010, 04:46 PM   #21
WigglesTheHoly
IT Guy/ Father/ Chevy lover
WigglesTheHoly's Avatar
I can't say I was ever told to hook them positive then negative..But it makes sense now that I'm reading this well the more you know I guess.
78 Chevy (Pictures) SOLD
79 Chevy LWB (pasture)
83 Chevy LWB (crushed rusted beyond repair)
02 TrailBlazer SOLD
03 VW Passat wagonSOLD
95 extended cab silveradoSOLD (still in family)
05 Crew Cab Silverado 5.3 (The Turd)
WTB: 66 El camino
Technology Specialist aspiring to be a gear head.
WigglesTheHoly is offline   Reply With Quote
