#1551 |
Re: PO has me PO'd
nice build i went through it a little while ago and i thought i posted but guess i didnt like how you are putting trim on the blazer that was one of gms mistakes not making a 67 68 blazer
#1552 | |
Re: PO has me PO'd
The problem with the '68 trim is the radius of the rear wheel well is not the same as the trucks, so I have to tweak it a little. Not sure how that will turn out...we shall see Always liked the '67 '68 front ends, just simple style with a bit of bling
#1553 | |
Re: PO has me PO'd
#1554 | |
Re: PO has me PO'd
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-09-2010 at 01:55 AM. |
#1555 |
Re: PO has me PO'd
oh that will be cool
#1556 |
Re: PO has me PO'd
I may have missed it but who makes the dual handle shifter kit? Thanks!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#1557 |
Re: PO has me PO'd
Off Road Design.com good stuff, but I have to try and bend the shifters at a 45 degree angle
#1558 |
Re: PO has me PO'd
Thanks for the link and the heads up!
#1559 |
Re: PO has me PO'd
![]() for the longest time I didn't know why I was leaking tranny fluid here, I was playing with my 'K' case TH350 and noticed these brass fittings. Seems like the PO didn't want to put back the strait threaded adapters, and just threaded the inverted flare fittings into the trans. Still have to get some crush washers, but for now just used some thread sealer. The adapters were tight going in, so I hope I didn't put any threads down into the tranny oh BTW, problem with the shifters on the twin stick, have to cut and bend or cut and weld or machine a block and bore and weld... ![]() ![]() ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-12-2010 at 08:25 PM. |
#1560 |
Re: PO has me PO'd
well what ever it is you will make it come out right
#1561 | |
Its lookin' like a Blazer!
Re: PO has me PO'd
#1562 |
Re: PO has me PO'd
Ill be down in the spring to take you up on the offer
#1563 |
Re: PO has me PO'd
OUTSTANDING! Maybe mine will be done and we can go for a drive.
#1564 |
Re: PO has me PO'd
You are one determined guy, We never see rust that bad out here. It looks like it coming together nice? How you digging those grinding boggers at the end of the day? HA HA (Been there on a 27 ford rodster I just finished)
Good luck and God speed
"The Can't Family Lives Across The Street" |
#1565 | |
Re: PO has me PO'd
![]() Hope I entertained you after all the reading ya did. We use salt on our roads in the winter and it just eats the trucks up. Thank goodness for patch panels ![]() I hate grinding!!!!
#1566 |
Re: PO has me PO'd
pics for AJ...glad to see you're still moving forward
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-31-2011 at 11:13 AM. |
#1567 |
![]() Join Date: Nov 2007
Re: PO has me PO'd
Perfect! Thanks Jim!
#1568 |
Re: PO has me PO'd
we need progress
#1569 |
Re: PO has me PO'd
Ill see what I can round up, rite now its wiring up the engine compartment, plus putting my tilt back together and installing it in the truck...amazing how many parts are in it
![]() also ordered the new Accel corrected HEI distributer cap, end of this week for delivery
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-01-2011 at 02:30 PM. |
#1570 | |
I miss this truck.
Re: PO has me PO'd
Thought about you today while i was spending what seemed like an eternity in the Philly airport waiting on a connecting flight.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
#1571 | |
Can't wait to retire!!
Re: PO has me PO'd
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
#1572 | |
Re: PO has me PO'd
Tynee, should of called me, we could've killed some time together Posted via Mobile Device
#1573 |
Re: PO has me PO'd
AJ, to answer your PM, that step in the cupholder is 1/8" thick at the smallest demension
![]() trying to wire up my electric water pump, once I buy the GOOD Vortec intake manifold gaskets, I may be able to run some water thru my cooling system ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-08-2011 at 08:32 PM. |
#1574 |
Re: PO has me PO'd
![]() finally foumd a place to mount the solenoids for my winch, not to much modification to the mount ![]() ![]() picked up the new corrected dist. cap from Accel, now all my spark plug wires from the left bank and right bank will stay to each side of the engine. Also, scored a NOS interior light (it's for a pickup, but should fit the 1/2 top), and my brackets for mounting my AM radio...thanks board members ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-12-2011 at 09:09 AM. |
#1575 |
Re: PO has me PO'd
wow great stuff! i love nos but dont have one nos thing on my truck!haha
