12-09-2010, 02:30 PM | #1 |
SB Motor Stands in right place?
I am finally starting to work on my truck. It's a small block automatic truck that I bought with no motor or transmission. The PO told me he had a small block with a 700r4 transmission in it. I have a mid 70's 350 with a TH350 out of an impala. I was looking at the engine stands and they look strange. they seem too far back and the hole in them looks like it's been hogged out. I know I may have to move the crossmember to put in the TH350, but want to make sure averything else is ok. Can someone tell me if they look ok, and if they are in the right place? I am attaching pictures.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. Last edited by FL71C10; 12-09-2010 at 03:25 PM. |
12-09-2010, 02:37 PM | #2 |
Project Junkie! Fishing Poor!!
Re: SB Motor Stands in right place?
They should be mounted in the forward 2 holes on the frame and the forward hole on the front end crossmember. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
12-09-2010, 03:54 PM | #3 |
Here's a picture
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
12-09-2010, 03:59 PM | #4 |
Other side
12-09-2010, 04:33 PM | #5 |
Look to be in the right spot. Someone wallered out to holes because the engine can be a bear to line up sometimes and the aftermarket motor mounts aren't always the best fit. So instead of taking the ill fitting motor mounts back and exchanging them, they wallered out the holes to make them fit. (I would change the brackets if it were me.) WES
12-09-2010, 09:02 PM | #6 |
Thanks, does anyone have a picture of them in the right place that they could post?
12-09-2010, 09:19 PM | #7 |
Just like to part out trucks!!
I can get one Fri after work
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
12-09-2010, 09:30 PM | #8 |
They look to be in the right place, just the motor mount holes are wallered out..this is our right side. Yes, I marked it right also just so we didn't bolt it on the wrong side.
12-09-2010, 09:47 PM | #9 |
I had trouble getting those bolts into the engine mount also. So I disconnected the towers from the frame and bolted them to the engine mounts and engine first. Then I use some tapered rods to get the towers lined up as I lowered the engine. Much better.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
12-10-2010, 01:01 AM | #10 |
The holes are hogged out pretty big, but as big as the washer is that goes under it, I doubt that it will cause any problems. I have seen the same poor fit issue on aftermarket mounts, & usually drill the holes in the stands out to 5/8" whenever the engine is out of one of these old trucks. crazyAl
http://community.webshots.com/user/hotrodhorn |
12-10-2010, 01:21 AM | #11 |
Is there a aftermarket one or ones from a newer truck that would fit? Maybe thatd be the best way to go???
1969 Chevy c20(Miss Hackjob) |
12-10-2010, 02:16 AM | #12 |
Big Red - Now its a SWB!
To get them to line up I leave the tower bolts loose then jack up the engine a little, get the engine mounts bolted to the towers, then tighten up the towers. Seemed to work well.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
12-10-2010, 04:50 PM | #13 |
this is generally my approach - get all the bolts in and started, then tighten stuff down.
12-10-2010, 07:36 PM | #14 |
But , who wants to play with the top & bottom bolts on the tower, on a motor mount swap? It should bolt out/in, no hassles. crazyAl
12-10-2010, 08:18 PM | #15 |
12-10-2010, 11:45 PM | #16 |
Thats why i drill the holes in the stands from 1/2 to 5/8"
12-11-2010, 12:06 AM | #17 |
What size bolt do I need to bolt through the towers Into the engine mounts?
12-11-2010, 12:12 AM | #18 |
Cruzin
my dad showed me a trick he used to do, i had one on the 67 i worked at for and hour he came out and ground a point on the end just like the sheet metal bolts are and used the air rachet and it went right in
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
12-11-2010, 12:17 AM | #19 | |
Not so sure about using a powered tool to start a bolt |
12-11-2010, 12:18 AM | #20 |
They are 7/16, 14 thead(NC). ...1" long should get you.
12-11-2010, 12:23 AM | #21 |
Cruzin
I tried aligning the hole with something and didn't work the point he made on the bolt is the main thing that did it he worked as a auto tech. for 30+ years so he has found a lot of tricks to use
