Truck Enthusiast
54' 3100 restore...my current project
This is my friends truck that I'm restoring for him. Started this weekend and got pretty far into it. This is my insentive to get my truck done next...so whatch for that build.
Got the bed off, sanded down, almost ready for primer. Engine and trans pulled. Gas tank behind the seat pulled. Whats going in: MII front suspension with rack and pinion. Fuel cell. Will be dropped on static, not air. truck is being built as a clean cruiser...gonna be shweet. I will be updating this weekly or as more work is done. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
'85 swb |
Truck Enthusiast
Re: 54' 3100 restore...my current project
'85 swb |
Truck Enthusiast
Cab off, chassis preasure washed, front mock up
'85 swb Last edited by droppedgmc; 12-12-2010 at 12:47 PM. |
Truck Enthusiast
'85 swb |
Truck Enthusiast
'85 swb |
Truck Enthusiast
Engine
98' vortech block and heads. 10:1 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
'85 swb Last edited by droppedgmc; 12-12-2010 at 12:11 PM. |
Truck Enthusiast
Put the engine/ trans and front shocks in tonight
'85 swb |
Truck Enthusiast
I also have the headers ordered...coated
![]() The CC2 header is only 4" tall. For very tight clearance connections this header provides excellent clearance. fits all GM straight and angle plug heads, plus Dart, Trick Flow, Brodix, Brownfield, and Edelbrock cylinder heads. Comes with all hardware necessary for installation. SPECIFICATIONS: Engine : Small Block Chevy 265-400 Primary Tube Diameter : 1½" Collector Diameter : 2½" Weight : 14 LBS / 6.35 KGS FEATURES: 16-Gauge Primary and Collector Tube Thickness 3/8" Thick Flange Patented Flange Design Requires NO Gaskets Tightest Fitting Header Available Anywhere! Made in the USA INCLUDES: Header Bolt Set OPTIONS: Our Aluminized Ceramic Coating is available and RECOMMENDED on all Sanderson Headers. We apply a multi-layer inside and outside silver ceramic coating in-house to meet our high standards of quality, and polish the coated header to a high luster. This coating provides aerospace and military technology to your vehicle to control the heat in your engine bay, improve cylinder scavenging of exhaust gases, and increase the longevity of your header investment. (read more here) You can select Thermal Ceramic Coating below, and the header price and part number will be automatically updated. Copper Collector Gaskets are recommended for all Sanderson headers (SEE RELATED PRODUCTS BELOW) Sanderson Headers do not include collector bolts due to our customers' wide range of preference. We do offer a collector bolt set that features Grade 8 Bolts with Locking Nuts (SEE RELATED PRODUCTS BELOW) NOTES: This header offers 1½" primary tubes, which is good for about 350HP on a casually used 350 cubic inch or smaller engine application. For larger or higher horsepower applications we offer this header with 1-5/8" primary tube sizes, Order #CC2_158. Will fit Mustang and Vega style steering as long as there is 2" of clearance between the center exhaust ports and the steering gear. The Patented Leak-Free Design that Sanderson Headers offer you is the only leak-free flange design on the market ... Do Not Attempt To Use Flange Gaskets! The raised flange on the Sanderson Headers will buckle the gasket during tightening and actually cause a leak! Sanderson Headers are NOT emissions legal on pollution-controlled motor vehicles. It is the purchaser's responsibility to verify local regulations for compliance. Wrapping your Sanderson Headers with ANY thermal tape voids your header warranty. The best thermal protection for your headers is our Aluminized Ceramic Coating that is available for every Sanderson Header. WARRANTY: Limited 5-Year Warranty (read more here) DIMENSIONS: (Right and Left Side Headers are the Same) Tube Size ............ 1½" Collector Size ....... 2½" DIM A ................. 2¾" DIM B ................. 4" Weight (Lbs / Kg) . 14 / 6.35
'85 swb |
Truck Enthusiast
got a little more work done today. radiator support and radi are in. mock up of inner fenders and supports. got a bunch of sanding done on the cab, i'll get pics of that tomorrow
'85 swb |
![]() Join Date: May 2005
very nice.... gotta nice clean look to it.
Truck Enthusiast
some body work getting done
'85 swb |
droppedgmc, Very nice build. Not too many 54-55 on here.
Certified Car Nut
Nice build, keep up the good work.
Hey neighbor looks like you getting some progress done,should be a sweet ride when your done.I use to live over in Roggen
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
#15 |
Looking good.
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
#16 |
Impressive work!
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
#17 |
nice!!!!
#18 |
Truck Enthusiast
Doors
![]() ![]() Tail lights. Going to be LED cadi's ![]() ![]() ![]()
'85 swb Last edited by droppedgmc; 01-11-2011 at 11:32 AM. |
#19 |
Truck Enthusiast
more light work. shaving the stake pockets
'85 swb |
#20 |
The tail lights look slick
55 2nd series Chevy Pickup 2019 Chevy Equinox(Daily driver) 2011 Chevy Malibu (Wife's car) MSRA Member I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose. -George Carlin |
#21 |
![]() Join Date: Mar 2005
Love it!
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#22 |
at that pace it will be finished in no time. nice work
1971 Corvette convertible 454@ 525 hp ![]() 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
#23 |
Truck Enthusiast
more light work
'85 swb |
#24 |
Truck Enthusiast
Rear Tails almost complete
![]() ![]() Paint ![]() ![]() Exhaust down pipe from header ![]() ![]()
'85 swb |
#25 |
this build is flying along! Looks great!
