Old 12-17-2010, 06:05 PM   #1
Squareforceone
Squareforceone's Avatar
Cheap/Easy ways to make engine bay look better?
Does anybody know of some cheap ways to spruce up an engine bay i was think some value cover and an air filter. Any inputs appreciated my just an unemployed high school kid so i dont have much money
Squareforceone is offline   Reply With Quote
Old 12-17-2010, 06:08 PM   #2
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Re: Cheap/Easy ways to make engine bay look better?
I know how that feels! Save up some money and you can get new valve covers and air cleaner that look cool if you like. If it doesn't run right though fix that first....also you can get under there and try to clean it with de-greaser and paint the brackets and stuff the same color..that looks pretty nice.....you can also paint the engine block if you want.....and if you don't mine being patient you can move wires around and hide them to make it look more organized...
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 12-17-2010, 06:24 PM   #3
Squareforceone
It runs pretty good but needs a better battery (this one wont crank when it gets cold) I am some what mechanically inclined i can change oil plugs and wires and basics and turn a wrench. But not like these guys on here can remove the engine to spruce it up so thats why i was saying easy. If i were to put on new value covers would i need to mess with gaskets or anything or just move the plug wires and take the covers off? Ill try and get some pics of the very dirty engine. Thanks i know that was a lot
Old 12-17-2010, 06:24 PM   #4
pig rig
pig rig's Avatar
wash it and keep it clean
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 12-17-2010, 06:31 PM   #5
THE "10" SILVERADO
You don't have to change the gaskets but I would recommend it when you change the valve covers...
Michael
Old 12-17-2010, 06:32 PM   #6
Pro Performance
Pro Performance's Avatar
Rattle can go a long ways. I am doing a budget build and just rattle canned the whole engine bay. Of course, I degreased it all first.
I think it looks alright for what it is.
Pro Performance is offline   Reply With Quote
Old 12-17-2010, 06:40 PM   #7
Squareforceone
I can't really just spray paint it all since i have NO way of removing the engine
Also i always though changing a head gasket was hard because we had a '79 lincoln continental hella of a car lol that had a blown head gasket and we sold it because of it
Old 12-17-2010, 06:44 PM   #8
THE "10" SILVERADO
You don't have to remove the engine to paint the engine compartment....I had a thread on it a while back......might take a little while to get all of the hard to reach places but it can be done.....http://67-72chevytrucks.com/vboard/s...d.php?t=432050
Michael
Old 12-17-2010, 06:51 PM   #9
Squareforceone
You dont have to but If doing while in don't you have to remove a lot of stuff (which i would screw up or forget about something)
Old 12-17-2010, 06:53 PM   #10
Squareforceone
Heres my dirty engine bay camera really makes it look dirty
Old 12-17-2010, 07:13 PM   #11
Restrorob
The One And Only !!!
Restrorob's Avatar
There are a lot of things that can be done on the cheap as others have mentioned, Small things go a long way in overall appearance.
Re-loom your under hood wire harness, Replace rusty or oversized hose clamps with the proper size. Clean/paint rusty screws and nuts, Rattle can anything that looks bad, Use news paper and masking tape to reduce over spray.
A nice clean/detailed engine bay can look just as good without a bunch of money or chrome bling, Add the bling after everything else is done.
When I judge shows 50% of my vote is based on the engine bay, That's where one's creativity out shines fancy wheels/tires and paint.
On Edit;
You have a camera, Take many pics of things before you take them off or apart for detailing....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 12-17-2010, 07:16 PM   #12
Allensracing
Allensracing's Avatar
clean clean clean. scrub scrub scrub.
Allensracing is offline   Reply With Quote
Old 12-17-2010, 07:20 PM   #13
Pro Performance
paint paint paint
Old 12-17-2010, 07:25 PM   #14
Allensracing
let me be a bit more specific and hopefully more helpful than my previous post.
assuming the picture you took is how it looks right now:
take off the air cleaner and snorkel. set it somewhere and clean it. if you have a place to wash pets or something like a laundry room sink, use that.
get every bit of dirt off of the air filter housing, and the snorkel.
if it looks like it has quite a bit of missing paint, scuff it up and repaint it.
once the air filer looks like brand new, put it back on the truck.
then find something else, and clean it.....
Old 12-17-2010, 07:30 PM   #15
nbpro
I would recommend using semi gloss instead of a gloss black or flat black . IMO just looks better. I use Purple Power and some engine cleaner. Think my engine turned out ok. And it was still in the vehicle. New wire loom and cleaned up hoses just makes everything look better.
nbpro is offline   Reply With Quote
Old 12-17-2010, 07:38 PM   #16
Squareforceone
So, Is it hard to change a gasket or not?
Old 12-17-2010, 07:47 PM   #17
Pro Performance
Yes, for someone that is not mechanically inclined, it will be a more difficult job.
Old 12-17-2010, 07:57 PM   #18
Squareforceone
But i dont have to replace it to take the valve covers off?
And im not totally clueless mechanically but i can't do what a lot of people on this site do and to an engine swap. I have never replaced a head gasket before but im sure i could probably figure it out with the help of the book
Old 12-17-2010, 08:04 PM   #19
nbpro
we talking valve cover gasket or the head gasket ?
Old 12-17-2010, 08:10 PM   #20
Squareforceone
valve cover gasket did i say head gasket i meant valve cover
Old 12-17-2010, 08:12 PM   #21
Pro Performance
I thought you meant head gasket.
The valve cover gasket is fairly simple. Sometimes you can re-use the gasket, but I would just recommend replacing it since you have the valve cover off. The valve cover gaskets aren't expensive.
Old 12-17-2010, 08:16 PM   #22
nbpro
^^ x2 just dont tighten bolts to tight
Old 12-17-2010, 08:17 PM   #23
N2TRUX
Happy to be here
N2TRUX's Avatar
I would recommend using semi gloss instead of a gloss black or flat black . IMO just looks better....
Very good advice. Satin black looks great and stay nice much longer than flat or gloss.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-17-2010, 08:17 PM   #24
Squareforceone
Sorry i was thinking of head gasket because they are cheap but hard. so valve gasket isn't that hard to replace? Thanks for all the help
Old 12-17-2010, 08:28 PM   #25
nbpro
your application may differ from the one in the video but it shows the basics.
