Old 06-24-2003, 01:54 AM   #1
BUXMAN66
go bucks!
do i need lowering shocks?
i've heard different opinions....i'm lowering my '68shrtbd w/ 3"frt. coils and 4"rear coils and need to know if i'm gonna need to order any.........anyone?thanks.
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 06-24-2003, 02:03 AM   #2
ocbaud
Garage Queen Material
yes, very much so if you are only using coils to drop your truck. try this though.
drop your truck and ride around with your current shocks, then order a set of GOOD drop shocks and then you will be like wowzers!
ocbaud is offline   Reply With Quote
Old 06-24-2003, 10:36 PM   #3
Chevy_68
Chevy_68's Avatar
have any of you guys tried those edelbrock ones on a droped truck, if so how are they
Chevy_68 is offline   Reply With Quote
Old 06-25-2003, 01:05 AM   #4
BUXMAN66
go bucks!
'preciate the response,ocbaud.will take it under advisment!
Old 06-25-2003, 01:13 AM   #5
ocbaud
i've heard only good things of the edelbrock shocks
Old 06-25-2003, 01:20 AM   #6
Chevy_68
Chevy_68's Avatar
good cause i was thinking about getting them
Old 06-28-2003, 11:58 AM   #7
Brad
Out of the carpool lane.
Brad's Avatar
You won't have to get them. At one point, I had 3" coils in the front and 2" drop spindles and was just fine. I went to 2"/2" upfront later on though. I have always had a 4" drop in the back and don't have any problems with standard shocks. I highly recommend that you get the rear shock relocators although they aren't needed either. They just give a slightly better ride.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 06-28-2003, 07:14 PM   #8
crazy longhorn
Fabricate till you "puke"
I have a 2 1/2-3" drop front, & a 4 1/2 -5" drop rear on the springs. I have relocated brackets both front & rear (front brackets are custom made, & the rears are just relocated on the leaf frame). I run stock lenght Monroe gas shocks, & the old truck rides good. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-12-2003, 05:06 PM   #9
Zorro_sn
Phat Ass Chevy
Zorro_sn's Avatar
i have edlebrock shocks, man those things are awesome, i used to have Toxic shocks and they were good, but eldlebrock mad a huge diff, also in money,lol $80 each but toxic shocks should be plenty, if u don't want to spend alot of money
Slammed...Shaved...Restored...
Before and After Pix
Zorro_sn is offline   Reply With Quote
Old 07-12-2003, 05:56 PM   #10
70c10
67-72 Addict!
70c10's Avatar
Keep us posted!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
