#552 |
Re: my 80 build
Keep up good work Aaron. Its going very nicely.
#553 |
6.0 powered square
Re: my 80 build
thanks guys, I plan on having the motor buttoned up by next week and maybe I can get a core trans mission so I can mock every thing up and order some headers
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#554 |
Re: my 80 build
Making good progress....Keep plugging away at it.
#555 |
6.0 powered square
Re: my 80 build
thanks john
got a little done today, but still need to torque the bolts, I planed on getting a junk 4l80e so I can mock up the motor But the trans shop my work does business said the 4l80s are stout and they haven't worked on many ![]()
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 12-03-2010 at 11:44 PM. |
#556 |
6.0 powered square
Re: my 80 build
well I got the camshaft retainer plate and sprocket torqued down, but I decided I'm going to get a new pump, and maybe I'll get it today and button up the bottom of the motor, timing cover, and possible valley cover, every part wheel get a new seal or o ring
#557 |
6.0 powered square
Re: my 80 build
I got the oil pump, wind-age tray, pick up tube, oil pan, timing cover, and valley cover installed and torqued down
#558 |
6.0 powered square
Re: my 80 build
I'm thinking about getting some dirty dingo motor mounts
#559 |
6.0 powered square
Re: my 80 build
this should be on there way
http://cgi.ebay.com/ebaymotors/ws/eB...m=180598301252
#560 |
Re: my 80 build
Looks good man!
#561 |
Re: my 80 build
can you run the factory LS ac with those?
1979 c30 3+3 dually 1946 GMC |
#562 |
![]() Join Date: Dec 2008
Re: my 80 build
Looks sweet Aaron
#563 |
6.0 powered square
Re: my 80 build
I'm not for sure but I won't be running a/c, the heat doesn't bother me just the cold does
thanks nbpro and John
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 12-10-2010 at 09:59 PM. |
#564 |
6.0 powered square
Re: my 80 build
got my dirty dingo mounts today they look great there even powder coated and might be getting a trans tomorrow from lkq
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 12-15-2010 at 01:05 AM. |
#565 |
Re: my 80 build
sweet man
#566 |
Re: my 80 build
Nice!
#567 |
6.0 powered square
Re: my 80 build
thanks guys called Larry at lkq and got the trans coming 4l80e with 107,000 and torque converter with 6 month warranty for 950
#568 |
6.0 powered square
Re: my 80 build
got the motor off the stand and bolted up the fly wheel
#569 |
TruckincrazY
Re: my 80 build
Did you get your motor through LKQ? Do they work with you on pricing or is it firm? That's where I'm thinking of getting mine from.
#570 | |
6.0 powered square
Re: my 80 build
well I got my transmission but the pan is full of metal so I'll send it back Monday and see what happens and also I have another problem my fly wheel has a 3 bolt pattern and the torque converter is a 6 bolt
#571 |
Slots go on anything!
Re: my 80 build
950 sounds a little high for the 4l80E. If they don't come through, call Robert at RCS in Tyler. 1.800.259.4020. They deliver here daily.
1974 Jimmy- 5.3/4L80e/NP241 Last edited by Jonboy; 12-18-2010 at 10:00 PM. |
#572 |
6.0 powered square
Re: my 80 build
I couldn't wait
#573 |
6.0 powered square
Re: my 80 build
it ended up be over 1200 with the core and taxes so, if I have any trouble sending trans back and getting one that doesn't have a pan full of metal I'll send it back and give them a call
#574 |
6.0 powered square
Re: my 80 build
well it looks like I need to get a fly wheel and spacer from a 6.0 that came with 4l80, then I need to get a arp crank pulley bolt and torque converter bolts, when I get another trans I'll check the pan if good then a new filter which I do have, degrease the trans and bolt it to up to the motor, mock up to the trans cross member and install the valve springs and bolt up the accessories
#575 |
6.0 powered square
Re: my 80 build
I yanked out the passenger side floor pan cover panel, and I going to replace it with a weld in floor pan, I ordered both sides from capt and also ordered a arp crank pulley bolt and torque converter bolts
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 12-20-2010 at 12:48 AM. |
