Old 06-24-2003, 09:56 AM   #1
dubie
dubie's Avatar
Will this distributor fit?
When I put my 350 in the inline position, will this big distributor fit? Is anyone running this same set up?
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 06-24-2003, 10:17 AM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
I've never had an issue putting a stock GM HEI in a small block 4x4, and those sit pretty far back in the engine bay. Can't speak for the V8 in the i6 position though.
Had you done the "proper" thing and put the small block where it's supposed to be, you would not have this question. Oh what a tangled web we weave... J/K
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 06-24-2003, 10:17 AM   #3
racedvl
racedvl's Avatar
It will fit, but It will be tight to the fire wall. When I put a 350 in my old 67 on the 250 mounts, I had HEI.
racedvl is offline   Reply With Quote
Old 06-24-2003, 10:21 AM   #4
dubie
dubie's Avatar
I had a really tough time deciding how to install this engine, but my budget is damn near gone and I want this thing to run. I also talked with 3 guys that have done the swap both ways and they say that putting the engine farter back is the way to go. When you put a V8 in the right place on a 6 cylinder truck, you get to much wheel hop at the rear. But when they did the same swap and put it in the inline position, they never had that problem. So that was one of the big deciding fastors.
Thanks for the input guys
Old 06-24-2003, 10:29 AM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
engine farter
If your engine is a "farter", wheel hop won't be an issue.
Good luck, the HEI should fit
Old 06-24-2003, 10:52 AM   #6
dubie
dubie's Avatar
HAHAHAHA FARTER!!!! me's and my's guud Inglesh eh
Old 06-25-2003, 01:06 AM   #7
ZOOMY
I6 4x4
What most guys here call the I6 position is the V-8 position in a 4x4 position. Waaaay back. It's difficult to get an HEI in & out, but once it's in there, there is just barely enough room for it. Some guys hammer the firewall for more clearance.
ZOOMY is offline   Reply With Quote
Old 06-25-2003, 01:09 AM   #8
jays68yak
jays68yak's Avatar
wow even drunk thats hard to read
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig
"I like long walks, especially when they are taken by people who annoy me. "
jays68yak is offline   Reply With Quote
Old 06-25-2003, 10:01 PM   #9
Don Smith
MSD sells a small diameter HEI. It is in the Summit catalog.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
Old 06-25-2003, 11:13 PM   #10
crazy longhorn
Fabricate till you "puke"
my 383 is in 6/250 position, & the body is aslo dropped 1 1/2" over the rails. The HEI fits , but is d@mn tight! it will go in/out of the eng with the cap & rotor removed. The firewall has been modified around the heads for a BB olds that I ran ......but the center of the firewall is stock(not hammered, or otherwise modified). when it comes time to replace that HEI, I am going to use the small cap MSD that Don has mentioned. Good luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
