transfer case exchange
hey guy im looking at swapping my np205 for a np208, anywho i was at pull-a-part over the weekend and they had a nice 87 blazer with a np208 in it but it was hooked to a 700r4, i have a 350 turbo, so my question is, does the transfer case have to come of a th350 or will one off a th400, 700r4, or even a maunal tranny work for me?
also other then the case, the shifter, and the floor hump, what else would i need to swap the 208 inplace of the 205 my rig is a 77 chevy 1/2 ton 4x4 |
Re: transfer case exchange
Any particular reason you are wanting to go from a HD totally gear drive case to a weaker chain drive case?
The adapters are different as well as the tranny output or T/C input spline count. Checkout Advanced Adapters or Novak. They explain what transfercases fit what trannys. If you are going to go for the 208, get the 700R4 also and pickup a 4th gear for the tranny at the same time. At least you benefit from slightly better fuel economy. You will also need the shifter assembly from the cab and all the linkage for the 208. Probably have to cut a different tranny hump hole as well.
03 Suburban Z71 Z71 98 GMC Yukon SLT 4x4 Yukon 86 M1009 CUCV Project Milverado 48 Willys CJ2A 48CJ2A |
basically i dont like the idea of being in 4x4 all the time, and i want the fuel economy of being able diesnguage the front end when not needed
Next!
![]() Join Date: Jan 2003
You sure you don't have a 203?
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
What he said...the 205 is the part time transfercase. The 203 is the full time. Do you have lockouts on the front axle?
If you have the 203 there is a part time kit you can get that changes the parts in the transfer case to make it part time. Post a pic of the transfer case.
guys im sorry u r correct, 203 is what i have and its killing my fuel mileage
no lockouts on the hubs
t350, 700r have 27 spline outputs. th400 is a 32 spline output
nickle and dime |
Now that you have confirmed you have a 203 you have a couple options. But to also benefit fully from this you will also need lockout hubs for the front axle either way you descide.
Option 1: (Most expensive) get the 700R4 with the 208 and probably the crossmember and the driveshafts, remember you need the shifter and linkage and will need to cut a new hole in the hump and patch the old hole as well. (here you will gain some fuel economy from the 4 gear OD transmission). Option 2: get a part time kit for your transfercase. These are pretty easy to install with basic mechanical skills and will require no mods to the driveshafts or anything other than what parts you swap inside the transfercase. This kit I found with a quick eBay search is one of the most popular and under $45 plus shipping so this is a win win here: http://cgi.ebay.com/ebaymotors/MILE-...Q5fAccessories Looks like he has the lockouts too for under $70 plus shipping: http://cgi.ebay.com/ebaymotors/MILE-...item45f7532d85
03 Suburban Z71 Z71 98 GMC Yukon SLT 4x4 Yukon 86 M1009 CUCV Project Milverado 48 Willys CJ2A 48CJ2A Last edited by 48cj2a; 12-19-2010 at 05:07 PM. |
im pretty confident i can do the transfer case part, but whats involved in making the front end locking hub? i know it cant be as simple as just putting the lockers on
#11 | |
Do yourself a favor and inspect and repack your bearings at the same time. Layout a shop towel, 6pack box flat, or cardboard and layout the parts as you disassemble. Once you get the chrome cap off, there is a big snap ring around the edge of the hub and one on the axle. remove the metal gear the ties the axle to the hub, the big tension spring, and the axle nuts n washer. Remove the hub, remove and repack the inner and outer bearings and repalce the seal. If you remove the 6 nuts that hold the spindle there another caged bearing that should be inspected and repacked inside the spindle. While you got the spindle out you can actually pull the front axles out and inspect the u-joints and replace if needed. When you go to put it back together there will be a new part time gear assbly that replaces the big metal one u pulled, and the lockout hub will bolt to that replacing the chrome cap.
78K & 79C Jimmys
Mine was done before i got it
seems to have been done right
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
here is a link on how to install the part-time kit in the transfer case http://www.coloradok5.com/milemarkerpt.shtml
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. ![]() 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
