Old 12-20-2010, 03:26 PM   #1
TimQ
Warm starting/choke problem
First the requisite details: 86 c10 4.3 v6 automatic with 90k original miles, rebuilt 4-barrel quadrajet put on last year with electric choke. Truck otherwise runs good.
I've had a warm engine starting problem crop up in recent weeks that I seem to have narrowed down to a problem with my choke.
If I drive till the engine is good and warm, then park the truck, wait maybe 20 minutes or so and come back sometimes it just won't start. When the problem happens, it turns over just fine and even "fires" for just a split second and dies. After that, no amount of cranking will do.
Last night I got it to happen in the driveway. I looked at the carb and noticed the choke was closed completely. I had my wife crank it while I held the choke open and she fired right up. Just for kicks, I repeated the process a few times (e.g. waiting 15-20 minutes before a restart) and it wouldn't start again unless I opened the choke.
If I try to restart right away after running the engine, it's fine. But if I come back between 20 minutes and an hour or even more later it won't start because the choke is closed. Four + hours later it starts fine.
It's been really cold here lately (not really been above freezing all month) so I suspect that thiis maybe causing the choke temp sensor to cool off quicker than the engine itself. Does that make sense? If so, how can I fix it? Is it an adjustment issue or is it a faulty part?
I've tried reading some related threads here but didn't seem to find the exact same issue.
Thanks in advance,
TimQ
TimQ is offline   Reply With Quote
Old 12-20-2010, 05:00 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: Warm starting/choke problem
Maybe a dumb question but, is the choke electronic?
Old 12-20-2010, 05:11 PM   #3
TimQ
Yes it is an electronic choke. Has a single wire going to what I believe is the controller for the choke on the passenger side of the carb. Here's a pic when I was putting it in last year.
Old 12-20-2010, 05:55 PM   #4
geezer#99
geezer#99's Avatar
Sounds like you need to lean your choke a bit. The 3 screws holding the black cap need to be loosened and the cap turned clockwise a couple notches. Should be some marks on it at the top and a mark on the choke housing for referencing it. You should see rich to the left and lean to the right.
geezer#99 is online now   Reply With Quote
Old 12-20-2010, 06:35 PM   #5
TimQ
Thanks...that's a lot simpler set of instructions than anything I could find searching online and in my stack of manuals here.
I'll head out and give it a shot and see what happens.
Old 12-20-2010, 06:46 PM   #6
Restrorob
The One And Only !!!
Restrorob's Avatar
Do you have a pic of the drivers side of the carb ?
Sounds like the choke pull-off is faulty or not adjusted properly.
Once you start cranking that builds enough engine vacuum for the pull-off to open the choke a little, This keeps the engine from flooding before it cranks.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 12-20-2010, 07:06 PM   #7
TimQ
Sure...here's a pic of the driver's side.
Old 12-20-2010, 09:34 PM   #8
Restrorob
Restrorob's Avatar
OK, Your model carb doesn't have a choke pull-off. All you can do for now is try leaning the adjustment like geezer#99 explained.
That would put less closing spring pressure on the butterfly....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 12-20-2010, 09:53 PM   #9
geezer#99
geezer#99's Avatar
He does have a choke pull off. It's on the other side. The amount of opening is controlled by the screw on the top.
Old 12-20-2010, 11:03 PM   #10
TimQ
OK, so on the passenger side of the carb (photo in post 3 above) there are two flying saucer looking things that I assume are the two choke pull offs. If I'm following correctly some other posts I've read, I guess one is tied to the primary (smaller plate???)and the other the secondaries (larger plate???). Which gets adjusted for this warm start issue? It looks to me like the back one controls the smaller place but before I mess with it I want to make sure I have it right.
Thanks again for all the great info.
Old 12-20-2010, 11:15 PM   #11
Restrorob
Restrorob's Avatar
Your right, I'm getting my pull-offs mixed up. You need to make sure the pull-off on the back is opening the choke butterfly slightly during cranking or right at start-up.
Put a longer piece of hose on it and see if you can suck on it and have it open the butterfly slightly.
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 12-21-2010, 12:34 AM   #12
geezer#99
geezer#99's Avatar
Now you got it restorob. Front one is for the secondary lockout. Back one pulls the choke plate open just after it starts. How much the choke plate opens is contolled by that little screw on top.
Here's a couple links.
http://www.florida4x4.com/tech/quadrajet/
http://www.vetteprojects.com/kstyer/quadrajet.htm
The second link is one found in the first link.
Old 12-21-2010, 10:09 PM   #13
D-Day
Live fast, die young
D-Day's Avatar
You might try adding a phenolic spacer between the carb and engine. Heat could be dissipating your fuel, and without a manual choke to override the lack of fuel, I can't imagine what cranking hell it must be with an electric choke and mechanical fuel pump. I have the same problem with my truck (no spacer yet) even with an electric fuel pump. Heat soak ain't fun.
D-Day is offline   Reply With Quote
Old 12-21-2010, 10:38 PM   #14
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
I had a similar problem on my computer qjet in my 86 Firebird. Had to replace the choke pulloff and adjust the set screw on it. The diaphram inside is probably leaking vacuum. You might want to remove it and see if it holds a vacuum. First with the engine off, push the pulloff rod all the way in and see if the choke linkage moves just a tiny bit. That may be out of adjustment. The pulloff is the front vacuum can between the choke thermostat and the MCS connctor.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 12-21-2010, 10:52 PM   #15
TimQ
Thanks all.
Had it happen again tonight. This time on the road while picking some stuff up at the store. I just took off the air cleaner cover and had someone crank it for me while I operated the choke and throttle from under the hood. She fired right up. I'm convinced its just an issue of the choke not opening at all when the engine is just a little warm. When it is HOT, it starts just fine - so if I shut it down and restart it within 5 minutes or so it works fine. It's the semi-warm start that gets me (say after 10+ minutes to more than an hour).
Anyhow, I'm going to try and mess some with the pull off and see if that is the issue. Hoping it's just out of adjustment.
