Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 12-21-2010, 10:51 PM   #1
low&slow
Have a terrible tranny fluid leak ?'sss
I have a 1994 blazer with a vortec v6 and it runs good but the transmission leaks really really bad. it leaks all out right between where the motor and tranny connects.
What's the problem?
And how do you fix it?
need answer's asap as its a daily driver. needs fixed by friday
low&slow is offline   Reply With Quote
Old 12-21-2010, 11:03 PM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Have a terrible tranny fluid leak ?'sss
I would guess a front pump seal at worst - might get lucky and its the dipstick
I would tell you to pull it and inspect it
It needs pulled if it is the front pump seal
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 12-21-2010, 11:14 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Sounds like a front seal to me pretty easy job to do in an afternoon..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-21-2010, 11:15 PM   #4
low&slow
I've had a lot of people tell me its the seal but they also say its a really hard job to fix. what does it consist of to fix the seal?
Old 12-22-2010, 02:37 AM   #5
ofnaman
ofnaman's Avatar
You have to remove the engine, or transmission (easier than the engine) to gain access to a front pump seal. If your not certain where it is coming from it may be worth taking to a repair shop and paying a little bit to have them diagnose where the leak is coming from, if it's leaking as bad as you say it is it should be pretty easy to spot the leak.
A sweet 2000 Deville.....
ofnaman is offline   Reply With Quote
Old 12-22-2010, 03:45 AM   #6
low&slow
I know for sure where the leak is coming from. but thanks. going to fix it tomorrow. thanks guys
Old 12-22-2010, 06:13 AM   #7
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I agree, front seal is bad.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-22-2010, 09:08 AM   #8
Tink
Tink's Avatar
On a gen 1 S10 Blazer??? On the gen 1s with the 4.3L, you can't get to the top transmission to block bolts unless you disconnect the motor mounts and jack up the body. .
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 12-22-2010, 12:58 PM   #9
spudz
spudz's Avatar
Front seal, but what made it go bad?? The bushing is probably worn out in the front pump. I ALWAYS put a new bushing in the pump if I am going threw the trouble of pulling the trans to replace a seal. I do this for a living and it costs me money to repeat the job so I always try to do it right the first time.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 12-26-2010, 12:54 AM   #10
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
4l60e's are notorious for a brass bushing leaking. It's probably not the seal. I've seen plenty of brass bushings fail. You can replace the bushing yourself.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 02-24-2011, 08:58 PM   #11
bighaas79
If you have to jack the body of the frame you aren't doing something right. I've done trannies in alot of these and have never once had to jack the body off the frame, or unhook the motor mounts. If you have access to a hoist and the right equipment this can be like a 2 1/2 hour job, but if you don't and don't know what you are doing u r looking at 6-8 hours. Maybe more.
bighaas79 is offline   Reply With Quote
Old 02-25-2011, 07:37 AM   #12
68C15
blood type; Retumbo
68C15's Avatar
keep in mind the pump to case Oring could be leaking. or the snout of the converter is worn. either way removal for closer inspection is in order
68C15 is offline   Reply With Quote
Old 02-25-2011, 03:52 PM   #13
Tink
Tink's Avatar
From my years on the S10 forums, lifting the body to remove the transmission isn't all that uncommon... it is either lift the body or remove the exhaust and transmission crossmember. The trouble with removing the exhaust is the y-pipe bolts attached to the exhaust manifold freeze/rust in place.
69 Chevy C10
88 Sierra
02 2500 Suburban
