Old 12-22-2010, 01:52 PM   #1
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Power Steering Pump Needs A Bath - Any Suggestions?
I took the Power Steering pump off to replace the rubber lines and this thing is in need of a bath real bad. I'm sure a degreaser of some kind is going to be the answer. Other than plugging the holes, should there be any other things I need to watch out for? What have you done? Any Suggestions?
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 12-22-2010, 02:14 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Power Steering Pump Needs A Bath - Any Suggestions?
Don't get any water in it. if you do make sure you dry it very good before using it. Mositure is the worst thing on a power steering pump.
Make sure it's pumping. I would take it and have it cleaned and tested at a hydrolic shop.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-22-2010, 02:34 PM   #3
myoldchevytruck
Thanks Andy
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 12-22-2010, 03:19 PM   #4
cdowns
cdowns's Avatar
i'd use kerosene and a stiffbush to clean it up
Old 12-22-2010, 04:14 PM   #5
Sammy
I think it's CPP has new PS pumps on sale for a X-Mas special $39 plus shipping. At that price you could do that, borrow a pulley puller from one of the chain stores and swap out your clean brackets.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 12-22-2010, 04:28 PM   #6
FL71C10
I think those are brackets for $39.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 12-22-2010, 10:49 PM   #7
myoldchevytruck
Thanks for the info guys
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 12-23-2010, 05:51 AM   #8
gysgtc
That is for just the reservoir at CPP. You still have to use your pump.
gysgtc is offline   Reply With Quote
Old 12-23-2010, 07:49 AM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You can get a complete reseal kit for your pump from the parts store for about 10 dollars. It's a very easy project to reseal one. This is one I did for Scoti and powdercoated all the parts during the job...
Remove the old front seal with a drywall screw...
Install new seal...
All reassembled with new seals on reservoir and fittings...
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-23-2010, 08:25 AM   #10
myoldchevytruck
Install new seal...
Kevin, what did you charge Scoti for powdercoating and resealing. I would definetly consider this after the holidays. You gave me a quote earlier in the year for powder coating a master cylinder ($45). I would send them both. Im thinking they would both fit in a large usps flat rate box.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 12-23-2010, 01:39 PM   #11
Tx Firefighter
I don't remember what I charged Scoti. We were working deals back and forth doing trading and such. It was washed in with a bigger deal I think.
I've been so busy building hay trailers that I haven't been doing any powdercoating lately. I'm gonna be covered up until the winter is over and folks quit buying hay before I can do anymore.
