inline 250 carb rebuild
hey i just picked up a new truck and the carb could used rebuilt, its a original carb and everything i was just wondering if there is anything i should watch for like special tools or anything. ive rebuilt holley double pumpers so its no big deal im just try to make sure i dont need anything special. thanks for the help guys
![]() Join Date: Feb 2010
Re: inline 250 carb rebuild
Nothing special needed. Have some carb cleaner/solvent ready to soak your metal parts. Compressed air is very good to have on hand to blow out passages. All the necessary parts should be in your rebuild kit. Just take your time and use the instructions. You should do fine.
what kind of carb is it?
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin 79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s 81 mercedes 300d 25 MPG 77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded" 73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091 '77 chevy trucks. built to stay tough. life is short build a hot rod ![]() |
i think its a stock rocchester but idk for sure
Carb kits are about 18 bucks its worth a rebuild .
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
yea thats what i was thinking to lol
i like that quote at the bottom ol skool chevy haha Measure with a yard stick Mark With Chalk Cut with a torch |
if its got the verijet 2bbl and it runs dont mess with it, but if its a 1bbl go to town and rebuild it. dad rebuilt the 2bbl on my 79 and it aint run rite since and he has rebuilt tons of carborators
the carb says its a monojet rockchester carb, im assuming its a 1 barrel carb you know mono, so next week it will be rebuilt i believe if i have money lol.
have any of you all painted a carb befor, ive heard of people using wheel paint any advise would be good. |
God is good!
Don't use just any paint because fuel will eat it up. Eastwood sells some nice carb paints. As far as the rebuild goes, it is very easy on that carb and well worth it. No special tools are needed, just the gallon of the stinky parts cleaner but it is pretty expensive. You can get by with using carb and choke cleaner, and if you don't have a compressor, you can buy a can or two of the compressed air. All hail the budget!
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
ok cool, well i got a new parts cleaner with brand new solvent in it so i should be set, and i do have a compressor. do you think autozone or napa sell any paint that could stand up to being on a carb, really dont want to have to order paint
My 79/80 has a 2 barrel. I say 79 cause it's a late 79 that was sold as an early 80 (round headlamps). Mine runs very lean according to the exhaust readings. One day when I get energetic I'm going to drill out the idle jet just a wee bit. I'd like to richen up the main too but I think I'd like to get a spare carb to molest first. When I got my truck the auto trans kick down cable was adjusted way to tight and the carb never did get to open the secondary. After the rebuild and the kick down cable adjusted correctly my 250 thinks it's a big block lol
![]() Sure would like to see a pic or your carb just so we know which one it is. |
Mono jet. Easy job. Just get everything clean, dont bend anything. New choke pull off diaphragm and save the paint it won't help a thing.
well bought my rebuild kit today from napa, hade to have it ordered lol, what a suprise they dont carry a rebuild kit for a 30 year old carb in stock lol only 38 bucks for the rebuild kit and a new float for safe measure. sure beats the rebuild price of a holley last one i did was like 70 bucks for a basic renew kit
#15 |
I've always used a wire wheel and some steel wool to clean them up instead of painting them. It almost gives them a polished look. I've got that same motor, btw, that I took out of my '80 and put in the 65 GMC. You should look into getting an HEI setup for it as well if it hasn't been done already.
My 68 cougar restomod build:HERE Last edited by SeanPaintsFlames; 01-03-2011 at 08:40 PM. |
#16 |
yea it already has a hei setup on it, what do you think of the power put out of your 250, does it have enough for a DD stock
#17 |
God is good!
Honestly, I would stay away from painting the carb. It will just cause issues, especially on a daily driver, but that's just my opinion. Here is an excellent thread on this issue...
http://www.jalopyjournal.com/forum/s...d.php?t=257012
#18 |
yea i guess i wont paint the carb just to make things easier
