Old 12-23-2010, 12:29 AM   #1
stepstep67
Talking 67 control arms
so am doing a disc brake conversion on my 67. i think i have it all figured out found a 76 gmc at a yunkyard i pulled the booster, master, discs, calipers and spindles and later found out i needed the drag link and brake hoses so ill b going bk for them.... am I missing anything???? ill be buying new ball joints and prop valve so i gt tht covered, also should i stick to my 67 arms or gt the 73-85 aswell??????? thanx
stepstep67 is offline   Reply With Quote
Old 12-23-2010, 12:29 AM   #2
67chevy1series
67chevy1series's Avatar
Re: 67 control arms
i would use your a arms
67chevy1series is offline   Reply With Quote
Old 12-23-2010, 12:33 AM   #3
stepstep67
Re: 67 control arms
thanx any particular reason? or jst because there already there?
Old 12-23-2010, 12:35 AM   #4
67chevy1series
Re: 67 control arms
there already there and i would rather have a part that is my yer model or original to my truck
Old 12-23-2010, 07:53 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 67 control arms
Get the front brake lines from the master cylinder down to the proportioning valve and the prop valve too. When you get all of the lines, you can bolt them to the early truck as a unit and have nice factory bent stuff. Personally, I'd buy new front brake hoses. I don't like to reuse something like that. They're made of rubber and they do deteriorate over the years.
Use the later master cylinder, all the lines, and hoses. The later model proportioning valve will mount to the front crossmember perfectly. I've done this on trucks from 63 all the way through 72 model. Here's a 63 I built last year. Every single brake line, hose, and master cylinder was from an 80 model truck I parted out.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-26-2010, 11:11 PM   #6
stepstep67
Re: 67 control arms
thanx i know cpp has the steel braided hoses for 60$ is that where u gt yours (i noticed those on ur pic)
Old 12-27-2010, 07:05 AM   #7
Tx Firefighter
Re: 67 control arms
The hoses on that truck are Russel brand from Summit for 73-87 trucks. I converted the whole truck over to the 73-87 lines front to rear.
