Old 06-24-2003, 09:11 PM   #1
bartamos
Two perches per side on RR axle??//?
I just bought a 1974 3/4T chevy 2wd truck. It has a C14BFF
rear axle. (Im pretty sure) it has TWO PERCHES per side on it.
The leaf spring are mounted on the innermost ones, they look added (minor rust and A- welding) the outer two are still painted
and Factory A+ welding. WHAT THE HELL , over? DID THEY REPLACE IT WITH A 1TON AXLE OR SOMETHING WITCH HAS A WIDER STANCE? BARTAMOS IS CURIOUS IN AZ.
bartamos is offline   Reply With Quote
Old 06-24-2003, 09:14 PM   #2
bartamos
How long am I going to be a junior.
Cant I ever Graduate? I have only Chevys. Whats my problem?
Old 06-24-2003, 09:19 PM   #3
rage'nrat638
rage'nrat638's Avatar
go to your user info and change it see mine????
after 100 post you get a avatar...picture....get posting...
your truck????who knows !!!!sounds like you got it figured out
welcome to the board .....
rage'nrat638 is offline   Reply With Quote
Old 06-24-2003, 09:21 PM   #4
bartamos
Thanx
Old 06-25-2003, 08:37 PM   #5
RockHQ
ROCKET POWER!
RockHQ's Avatar
It could be that the rear end is from a G30 Van.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 06-25-2003, 09:14 PM   #6
bartamos
Is there anything better or worse about it if it is, besides the extra purch or are all 14bff basically the same. it does not seem to be overall wider just that the frame/shackles must be wider
on bigger trucks/vans???
Old 06-25-2003, 10:52 PM   #7
Scrub
Collector of rusty Items
Scrub's Avatar
I don't know what the C14BFF stands for, But I would bet the axle was once on an earlier 4x4, which has narrower spring width.
It sure won't hurt anything, but it blows the original equipment theory all to heck.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 06-25-2003, 11:21 PM   #8
bartamos
corporate 14 bolt full floating c14bff. Anyway, the purches that are used on the truck now are the INNER ones so whatever its off of is wider. Thats what Im thinking. Thanks for the post.
A G30 is a good bet, that Came from RockHQ.
Old 06-26-2003, 12:00 AM   #9
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
any chance of you posting a picture?
I agree sounds like it was off a van or heavy duty truck or maybe a later model (92+?) truck...
it should be the correct width no matter what.. I cant think of any vehicle that had a special width 14FF
mike
mike reeh is offline   Reply With Quote
Old 06-26-2003, 01:26 AM   #10
bartamos
Great Idea. Ill do it tomorrow. will you please watch for it?
I want to sell all the stuff off the truck including the FF so I need to know what to say to someone except "spare perches?"
Im going to crawl under the next G30 I see and measure the
spring to spring distance to see if it matches the "outer" set
of perches.
Old 06-26-2003, 02:16 PM   #11
bartamos
My .jpg's are about 500KB. max here is 100. What do I do.
