#126 |
Re: 68 C 10 stepside "My American Bulldog"
It is motivating me for a ride to leesburg to drop my truck off at your house..lol Merry Christmas Spike!!!
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern" 1984 Silverado Red Baron-72 c10 Project |
#127 | |
![]() You can not turn my hobby into a job. It would take all the fun out of it!!! ![]() Spike ![]()
68 stepside http://67-72chevytrucks.com/vboard/s...0&goto=newpost |
#128 |
but you would be doing what you love best
#129 |
Between 46hrs/wk on my job(2,2,3 rotating day to night)
20-30hrs/wk working on my truck If I started working on another one also, I would be a miserable S.O.B LOL!!!! Spike ![]()
#130 |
#131 |
Merry Christmas and a Happy Holidays to everyone
Spike ![]()
#132 |
#133 |
What did you use for your paint stripping and was it much trouble to take off? Also Merry Christmas from S.E. Georgia
#134 | |
A cheap paint brush, 1 square foot at a time. If it sucked it up, I'll coat it with a little more. Let set for about 10 min. Then I use a 1" putty knife, (That I rounded the corners) to get the bulk off. Apply a thin coat of stripper as needed in between wire brushing lower layers When I get close to the metal, I use a medium wire brush (welding supply) Wipe all remaining stripper clean with Acetone. Then treat all exposed metal with phoscote, To neutralize any rust. And it leaves a zinc coating, To keep it from rusting in this South Georgia humidity. Keep in mind, Mine had 9 layers on it. You may not need a putty knife. Then later on, Crob35 reminded of another stripping technique, Using Saran wrap. I had heard of it before, But never used it. So I tried it. It worked great! First You apply a generous amount of stripper. Then you cover it with saran wrap. The quicker and smoother you can get the saran wrap on, The better. You are trying to keep the air out. After 8hrs or more, Pull the saran wrap off, And remove all the loose paint. Most will come off easily with a putty knife. One more light coat of stripper, And a coarse scotch bright, Or wire brush. Will remove anything that's left. Then I coat it with phoscote to neutralize any rust, And prevent it from rusting, Until I prime it. The picture below, Shows 1st cleaning at the top, Final cleaning in the middle, And phoscote at the bottom. This is the easiest way I know of. Spike ![]()
#135 | |
with a kandy baby blue and white pearl, Riding on a set of Corvette ralley rims, And baby moon centers. ![]() Spike ![]()
#136 |
Got to play for an hour or so today.
Installed the water pump And alternator. But I'm thinking about some new billet mounts for the alternator, And power steering pump. Spike ![]()
#137 |
Awsome build.Im in the same shape that you are..... No Shop to work in. My shop build starts Tuesday!!!!!! I cant wait to start my 72!!
#138 |
Love the old caddy air cleaner too spike.
#139 |
That beast is huge isn't it. LOL
Fits a 14x4 K&N filter as well, No breathing problem here ![]() Spike ![]()
#140 | |
Spike ![]()
#141 |
Installed my new rear track bar today.
![]() I only have a 4" drop, So I went with the 24" double adjustable from CPP. Ended up with 9 3/8" from frame to tread line on both sides. It adjusts similar to a tie rod connector. Spike ![]()
#142 |
looks good
#143 |
Grandpa in the rustmobile...
Looks good! Did ya go thru CCP or there ebay store (cheaper)
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#144 | |
I bought it from CPP site online Spike ![]()
#145 |
so are you going to use that air cleaner
#146 |
But of course!
Help it do some heavy breathing. With a little help from my Holley Spike ![]()
#147 |
nice i want a 67 factory air cleaner but i hear that they dont breath here
#148 |
Is the air cleaner factory caddy or after market? Looks good I am thinking of getting one myself. Where did you score it?
#149 |
Ive seen em in speedway catalogs
spike, what'd they charge ya thru CCP, or do you mind..(Ive gotta buy one soon)
#150 |
srea76, I picked up the air cleaner on Ebay, For just under $100 w/shipping.
oldblue1968chevy, I think the track bar was about $65 total. Spike ![]()
