Camaro SS Intake
Hi All I have a 2008 5.3 engine from a silverado and was wondering wold the intake from a 2010 Camaro SS fit. Also what modifaction would have to made if any. Thanks for any help.
![]() Join Date: Aug 2004
Re: Camaro SS Intake
I believe you would have to have all the Camaro front accessories for that Camaro intake to work.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Thank what would be a better lower profile intake that wouldn't involve me swapping all the accessories.
I dont think you can change the intake without changing the accesories because the car intakes sit alot lower than the truck ones and stuff gets in the way. Why do you want to change? for the cool factor? looks? the truck intake will give you more lower end torque but the car intake will give you higher revs....I think that is how it goes. Also you might want to check out LS1tech.com and ask the question too.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 12-27-2010 at 01:46 PM. |
Look into dirtydingo. (Google)You can get brackets made to keep your truck accessories but use a car intake as well. Also im not sure that the new camaro intake will fit on the 5.3 heads. I think the intake ports are different. One being cathedral port and the other being rectangle. Just something else to look into
Posted via Mobile Device |
69' Chevy Stepside
![]() Join Date: Mar 2008
If your 5.3L has cathedral port heads (which I'm sure it does) the 2010 Camaro SS (LS3) intake will not work because it is designed for square port L92 type heads as well as the accessory drive issues mentioned above.
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
