Old 12-28-2010, 09:20 PM   #1
fuchster
fuchster's Avatar
Help E Brake
Hello,
I need a picture of the emergency brake frame bracket (parking brake) on a Task Force truck. It has been so long since I removed that I do not remember how to put it back. I took the rivets off. I now need to relocate it a few inches back.
I need to see the bracket and how the cable attaches to the lever on the frame bracket.
Thank you,
fuchster is offline   Reply With Quote
Old 12-28-2010, 10:18 PM   #2
DransportGarage
DransportGarage's Avatar
Re: Help E Brake
Hope these help some...
I don't have any up near the front of the cab.
Bob
DransportGarage is offline   Reply With Quote
Old 12-28-2010, 11:24 PM   #3
hsdropout
Re: Help E Brake
stock location on my '59 1/2 ton.....a couple inches back from frame deformation for steering box......
hsdropout is offline   Reply With Quote
Old 12-29-2010, 08:31 AM   #4
72Mountaineer
72Mountaineer's Avatar
Re: Help E Brake
Has anybody used a different type of brake pedal, such as one from a 70s car?
72Mountaineer is offline   Reply With Quote
Old 12-29-2010, 01:27 PM   #5
fuchster
fuchster's Avatar
Re: Help E Brake
DransportGarage, hsdropout,
Thank you very much for the pictures. I have been looking on the web for days with negative results.
I want to keep the E brake somewhat original. I have a Lokar universal kit but I really like the brakets and levers under the cab as well as the bracket on the frame. And most important the brake handle in the cab. Now I just need to get a hold of Control Cables and order a new set of cables.
Next time I will take pictures before I take things apart.
72Mountaineer,
I still have the OEM pedal but I will change to a flat shaft pedal to match the accelerator shaft.
Again, thank you all for the pictures.
Old 12-29-2010, 01:41 PM   #6
OrrieG
OrrieG's Avatar
Re: Help E Brake
Look at my build thread, I used a 74 truck inside foot pedal assemby and cable mated to the stock back linkage.
Old 12-29-2010, 05:12 PM   #7
fuchster
fuchster's Avatar
Re: Help E Brake
I like it!!! That would have been option two. Specially if it releases when you push on it....
I got to do my can corners as well.
I see you replaced the lower door hinge caged nut...IS that working out with just replacing the lower portion and not the whole hinge pocket?
Thanks for the help.
Old 12-29-2010, 08:43 PM   #8
OrrieG
OrrieG's Avatar
Re: Help E Brake
On the driver side I had to replace the complete hinge opening. On the passenger I only replaced the lower half that was rusted out. I always leave as much of the original as I can (cutting back to good metal) so that hopefully the alignment is ok. I haven't hung the doors yet but do not think I will have issues I took measurements from the step at the bottom and side to the original nut locations and am less than 1/16th off my measurements. The nut has about 1/4" play in all directions so I'm ok.
The truck brake has a pull hand release that mounts under the dash.
