Old 11-30-2010, 11:36 PM   #1
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Finally done with my headers and dual exhaust
Hedman Elite Hedders with HTC coating, #69890. The only problems I had with them was the pass side hit the fuel and brake lines running along the frame. Just had to bend them out of the way a little. Also bolting up the compressor and steering pump bracket to the header. Instructions say construct a simple spacer. Well I ended up using a bunch of washers ground flat along the header tube side and they still don't seem to line up very well.
The exhaust is 2.5" mandrel bent Flowmaster pipes that exit behind the rear wheels and 2 Dynomax Ultraflow mufflers. Next weekend I'll put in the Gibson tips and post the pics.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 11-30-2010, 11:37 PM   #2
Justins76
Justins76's Avatar
Re: Finally done with my headers and dual exhaust
The exhaust from underneath.
My cardomain page
Old 11-30-2010, 11:39 PM   #3
nbpro
good looking exhaust
nbpro is offline   Reply With Quote
Old 12-01-2010, 12:06 AM   #4
lilpoindexter
lilpoindexter's Avatar
Do you get a pop gun sound effect when you floor it? I did on a caprice I had a few years back with no cross over.
lilpoindexter is offline   Reply With Quote
Old 12-01-2010, 04:46 AM   #5
GMC Guy
GMC Guy's Avatar
the exhaust looks great! i bet it sounds pretty good
did you have a shop route the pipes for you? also, any info on that rear sway bar? thanks
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 12-01-2010, 10:34 AM   #6
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Do you have any pictures of your makeshift spacers?
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 12-01-2010, 10:46 AM   #7
Pop's C-10
Pop's C-10's Avatar
nice work
Pop's C-10 is offline   Reply With Quote
Old 12-02-2010, 12:41 AM   #8
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
There is a bracket available through Jeg's or Summit (or others) specifically for compressor. How difficult is spark plug access?
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 12-02-2010, 01:26 AM   #9
Justins76
Justins76's Avatar
Nope, none at all.
My cardomain page
Old 12-02-2010, 01:28 AM   #10
Justins76
Justins76's Avatar
I did it all myself. Flowmaster sells the prebent over the axle pipes. Then I ordered a 6" s-bend pipe from the collector to the muffler.
The rear bar is 1 1/8" from Beltech.
My cardomain page
Old 12-02-2010, 01:28 AM   #11
Justins76
Justins76's Avatar
I will try you get some.
My cardomain page
Old 12-02-2010, 01:30 AM   #12
Justins76
Justins76's Avatar
I got that bracket from hedman(and it didnt fit well. I compared it to the stock bracket it it was off by about half an inch) for the rear of the compressor. But another bracket is needed for the lower front where it ties into the steering pump and all the instructions says is make your own simple spacer.
Spark plug access is easy using a box wrench.
My cardomain page
Old 12-10-2010, 09:54 PM   #13
Justins76
Justins76's Avatar
Here's where i used washers.
My cardomain page
Old 12-29-2010, 04:56 AM   #14
GMC Guy
GMC Guy's Avatar
can you post the link for those S bend pipes? they look to fit perfect, and i'm trying to fab my own exhaust as well
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 12-29-2010, 01:20 PM   #15
manimal
manimal's Avatar
That looks very nice. You could always get some 3/8"id 1/4wall tubing and make your spacers. Nice work.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 12-29-2010, 01:35 PM   #16
jchav62
1962 C-10
jchav62's Avatar
Excellent work. How do those mufflers sound compared to Flowmasters?
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 12-29-2010, 10:01 PM   #17
Justins76
Justins76's Avatar
Exhaust Tubing, Mandrel S-Bend, 2 1/2 in. Diameter, 16-Gauge, Steel, Aluminized, Set of 6
Part Number: FLO-15905
My cardomain page
Old 12-29-2010, 10:03 PM   #18
Justins76
Justins76's Avatar
I was going to try to find some pipe somewhere to make a spacer but I just bought a serpentine belt setup so that should fix everything up.
My cardomain page
Old 12-29-2010, 10:04 PM   #19
Justins76
Justins76's Avatar
I never used flows but these are quiet at idle and have a deep tone at wot. No raspy sound.
My cardomain page
