Old 12-28-2010, 09:46 PM   #1
foz
foz's Avatar
Drum drop spindles?
crazy for not wanting to upgrade to disc brakes in the front, I know, but I want to keep my 6 lug drums up front on my '70 SWB stepper.
I've got 2" drop springs and wanted to get an additional 2.5" drop with spindles without the brake upgrade for a total of 4.5" in the front.
Is there anyone out there making these drop spindles yet?
foz is offline   Reply With Quote
Old 12-28-2010, 09:51 PM   #2
Mike J
vw guy & now c-10 guy
Mike J's Avatar
Re: Drum drop spindles?
not that i'm aware of. but you can keep 6-lug and go to disc. That's what i did. used parts from CPP
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 12-28-2010, 10:08 PM   #3
68 Stepside
huh?
68 Stepside's Avatar
I did the same, bought my kit from GMC Paul.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 12-29-2010, 12:49 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by foz View Post
....Is there anyone out there making these drop spindles yet?
Not that I am aware of, and I doubt they ever will.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-29-2010, 05:24 PM   #5
foz
foz's Avatar
How about lowered lower control arms?
Has anyone gone this route?
What are the good/bad? Who would you recommend purchasing them from?
Old 12-29-2010, 06:18 PM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
cut some coils and get the same result?
John
1999 Toyota Tacoma 4x4
Old 12-29-2010, 07:13 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
he's already got the drop coils and any more is a N0-no for scrub line issues. The drop lower control arms also have scrub line issues. They do allow you to keep your drums and drop an additional 2.5", but you will have problems if you ever have a flat or major problems if you ever have a blow out on the front while driving....
...or as mentioned...get 6 lug discs....but then you also need to consider your prop valve/master/booster situation...
Old 12-29-2010, 07:38 PM   #8
foz
foz's Avatar
Exactly why.
I remember a post where someone made their own drop lower arm by cutting out the spring pocket and welding in a new pocket out of large diameter pipe.
Anyone else remember this thread?
Old 12-29-2010, 07:54 PM   #9
oldblue1968chevy
spraybombs
http://67-72chevytrucks.com/vboard/s....php?p=3450341
John
Old 12-29-2010, 08:44 PM   #10
foz
foz's Avatar
Hey VA72C10,
I was looking at this thread of yours
http://67-72chevytrucks.com/vboard/s...=404906&page=4
and noticed you used lca's with the ball joint cut off and welded back on in a raised postion for a drop.
any problems running like this? I would think the angle of the pocket would need to be adjusted. Any alignment issues?
Old 12-29-2010, 10:46 PM   #11
oldblue1968chevy
I think its kinda like a drop spindle (doestn change geometry, or you can adj. the geometry...?)
John
Old 12-29-2010, 10:50 PM   #12
SCOTI
SCOTI's Avatar
Dropped coils & dropped a-arms will put the spring pocket well below the scrub line if using 15" wheels.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-29-2010, 10:59 PM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
It amazes me how much effort your willing to exert to avoid an upgrade that pertains to making your truck safer to drive.
Articles-
"Refining Sierra"
Old 12-29-2010, 11:02 PM   #14
oldblue1968chevy
Discs will help alot.
Order some pre 71 drop spindles from ECE, and some 6 lug rotors and a prop. valve
The rest can be bought at orielly, (calipers/pads/MC) If you REALLY have the $ to spend, rebuild the frontend. Or better yet get a 73+ k member and swap it all, 73+ DS seem to be cheaper and easier to find too!
John
Old 12-30-2010, 09:54 AM   #15
foz
foz's Avatar
No effort put forward yet, just a few posts.
Just trying to understand the options from all angles. I see this as a good thing-right?
I don't really like any of the options I'm seeing that are available to keep the drums for the short period so I think I'll just do the 2" spring drop up front and get the 2.5" extra I'm looking for later with spindles along with the brake upgrade.
Thanx for everyones help and concerns.
Old 12-30-2010, 11:42 AM   #16
VA72C10
VA72C10
VA72C10's Avatar
makes sense now that you say that...I had read it posted it otherwise....I will edit my post so no one reads it and is misinformed....
I assume the advantage to a drop arm vs just a shorter spring is keeping the same compression ratio spring...does it also help keep the steering geometry better than a larger drop coil would?
Old 12-30-2010, 11:47 AM   #17
19seventeeCustom
why in the world would you want to keep drums for the front?
There are much better solutions to your problem of wanting a lowered ride, that many companies have already spent R & D on. Problem solved!!
19seventeeCustom is offline   Reply With Quote
Old 12-30-2010, 12:51 PM   #18
SCOTI
SCOTI's Avatar
Correct. Drop in height w/o a change in the springs rate. They do not help w/the geometry.
For many it's finance related. My personal philosophy is upgrading to discs is a must; not a want. Not everybody agrees.
Swapping some shorter springs for drop is relatively cheap. Upgrading to discs @ the same time adds cost if the current brakes are deemed acceptable by the owner (no problem to solve).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-30-2010, 01:12 PM   #19
19seventeeCustom
Oh, I understand the finance side of things completely, but when he already has a drop spring and wants to use a drop spindle, you gotta do what you gotta do. There aren't really any more options without spending money.
But trying to come up with other solutions like a drop A-arm is just quite rediculous when there are much better/safer options out there.
but hey,, thats just my opinon.
Old 12-30-2010, 01:48 PM   #20
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
Personallly I would say you should hold out and keep saving.....
I wouldn't let my son ride in the truck other than around the block trips until I installed a disc/booster kit. imho it was just to dangerous driving at freeway speed in so cal with drums.
On the flip side I encouraged wy wife to go on cruises and not wear her seat belt as she has a really good life insurance policy...lol (j/k)
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 12-30-2010, 04:41 PM   #21
camaney
So what do think about the 18 wheelers? they are all drums and can carrie a big load. Jmo
camaney is offline   Reply With Quote
Old 12-30-2010, 05:30 PM   #22
VA72C10
VA72C10
VA72C10's Avatar
big rigs aren't exactly known for their good stopping distance and why are there the emergency runoff areas for them on mountains?
Old 12-30-2010, 05:34 PM   #23
19seventeeCustom
They also have an engine brake to boot.
Old 12-30-2010, 05:36 PM   #24
camaney
Cool Re: Drum drop spindles?
Ok so try loading your truck as much as you can. Even with disk brakes you have to be more careful and slow
Old 12-30-2010, 06:08 PM   #25
N2TRUX
Happy to be here
N2TRUX's Avatar
Try comparing apples to apples. Yes there are vehicles with drum brakes that are capable of stopping just fine. In this case, replace inferior drum brakes with disc brakes is a HUGE improvement. Argue it from what ever angle you prefer, but the drum brakes on these trucks were never adequate.
Articles-
"Refining Sierra"
